how to get the...
Old Apr 8, 2007 | 11:13 AM
hwcoll95's Avatar
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
how to get the...
c clips out if you have an auburn posi,i need to change axles,but can't figure out how to get the c clips out,the clutches with springs seem to block the area to get the clips out??? HELP!!
Old Apr 8, 2007 | 01:36 PM
hwcoll95's Avatar
Engine: 355 carb'd
Transmission: 5spd
Re: how to get the...
ok figured it out,just the damaged axle is the prob,hammer time i think?
Old Apr 8, 2007 | 11:36 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
After you remove the crosspin from the carrier you will need to push inwards on one axle, take a pen magnet and pull the c-clip. Then do the same for the other axle. You shouldn't need a hammer to pull out the axle.
Mexinugget
Mar 18, 2015 12:44 PM
HCR13
Fabrication
18
Feb 10, 2011 12:30 AM
Cam-aro
Camaros Wanted
Dec 13, 2009 10:37 PM
BADMAN
South Central Region
Jul 11, 2009 11:35 AM
