Rearend carrier question??
Old Apr 15, 2007 | 06:57 PM
xgtharo86x's Avatar
Car: 86' Trans am
Engine: 85 LG4-non cc carb(building a 350)
Transmission: Rebuilt 700R4,vette servo,2200stall
Axle/Gears: 2.73 Posi
i have a 86 t/a and its an open carrier..im goin to the junkyard soon and i was wondering what spline i have and what cars have the same?? thanks
Old Apr 15, 2007 | 07:10 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
Re: Rearend carrier question??
as of 1986 the 10 bolts had 26 splines. late 89 they swapped to 28 splines.
you looking for a car that has the same spline count? or the same size carrier?
Old Apr 15, 2007 | 07:21 PM
xgtharo86x's Avatar
Car: 86' Trans am
thanks...spline cuz i know it changed the size is 7.5 right
Old Apr 15, 2007 | 10:06 PM
novatuc's Avatar
Car: 1984 Trans Am
If you are just looking for the carrier, do a search on the net. Lots of GM vehicles had the 10 bolt 26 spline carrier, just the axle housing and the axles themselves were different lengths so they don't interchange. If you are just looking for a gear set or a posi unit, Astro vans, S-10's, some Monte Carlo's, etc. all interchange the stuff in the housing.
Old Apr 16, 2007 | 01:19 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Unfortunately the only donor car for a posi is another '82-'88 Fbody as far as I remember. Another one of the 3rd gen parts that you can't steal from another GM vehicle.
Astro, S-10, etc, used either an open rear, or the dreaded gov lock. (you're better off with an open, less shrapnel).
Not sure about the Monte's though.
Old Apr 16, 2007 | 03:00 AM
ede's Avatar
ede
find a carrier from a donor car and get the axles to match. that'll open up a lot more possabilities for you.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
knight72
Aug 10, 2015 09:32 PM
