trans temp question
Old Apr 16, 2007 | 12:10 AM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
trans temp question
what would be better putting the probe in the pan, or on the line going to the cooler? i would like to put it in the pan but i don't have a drain plug so i would have to weld in a bung, the line seems eaier but it might not be as accurate. any suggestions?
Old Apr 16, 2007 | 12:28 AM
Re: trans temp question
i found this...http://www.glowshiftdirect.com/index...ROD&ProdID=305...where would this go?
Old Apr 16, 2007 | 08:35 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
I use to have one in the return line form the radiator so I knew how cool the tranny fluid was. To do that you would need a "T" fitting and some compression fittings for the connections to the tranny lines.
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
gta power
Aug 13, 2015 06:15 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
