transgo boost valve?
Car: 1990 RS
Engine: 305 carb
Transmission: 700r4 with transgo shift kit
Axle/Gears: ?? not sure yet just got the car
ok i know im stupid for doing this and I dont know how i did it... i installed the transgo kit for my 700r4 the other day and well... somehow I got the boost valve completely stuck in the trans and cant get it out... any suggestions on what I should do??? am i gonna get charged for a complete rebuild or can they fix it easily??? i pretty much lost revers and now if i even attempt to romp on it it wont shift due to lack of pressure... i really need help with this
Re: transgo boost valve?
Make sure that the snap ring "is not" in there. Put the transmission in reverse, and give it gas very quickly, this should knock the valve into the pan.
Car: 1990 RS
Engine: 305 carb
ok Dana, Ill give that a try... if that doesn't work any other suggestions??? im trying to get all the advice I can before I tear it apart tonight so I figured my odds would be better to get it out...
Car: 1990 RS
Engine: 305 carb
well the valve didnt come out by taking out the snap ring and putting it in revers and hitting the gas.... the valve will move a tad up and then stick again... i think i am going to have to drill a hole in the middle of the valve and put a heavy duty screw in it and use a slide hammer to get it out and sinstall a new valve ill let u know
Car: 1990 RS
Engine: 305 carb
ok well i got the tv boost valve out now the reverse boost valve wont come out... almost there lol
Car: 1990 RS
Engine: 305 carb
ok well i got the new boost valve and reverse valve out and I found out why it got stuck in the first place... im guessing the previous owner had some trans work done before and there is a gouge in the cylinder where the valves go... causing it to go in kind of go in crooked and NOT want to come back out... question... is that part of the trans shell or should I just start shopping for a new tranny??
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
The valves plug into the pump. You can buy a used pump and rebuild it, or buy a reman pump.
Sounds like you have no luck.
Doobie52
Sep 11, 2015 06:19 PM
