Quick Change Rearend?
Car: 1989 RS
Engine: LO3 5.0L
Axle/Gears: 10b 2.73
does anyone know what brands of quick change rearends are out there and if anyone makes the stuff to put them in a 3rd gen? i'm thinkin about using one in my 84 to make it good for use in dragracing and maybe roadcoarse/salt flat use. maybe i'm dreaming, but i just want a versitile, all purpose car....
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Quick Change Rearend?
Closest thing you're going to find for a third gen that could be considered a quick change is a Ford 9".
The typical quick change diff commonly found in old Tee roadsters or Outlaw dirt track cars isn't going to easily fit. You would have to do a complete custom install. These old diffs also used straight cut gears. Although strong, they're also very noisy.
I'm assuming you're looking for something like this. Not exactly cheap.
http://www.speedwaymotors.com/p/5062...-Rear-End.html
http://www.pitstopusa.com/SearchResu...CategoryID=955
Car: 1989 RS
Engine: LO3 5.0L
well, the richmond unit w/ the 4.11's for $1500 is right in line w/ the Currie 9 bolt in unit. and i can buy/fab up the majority of the brackets. if the center section is aluminum, i can have a buddy of mine tig weld the torque arm brackets to the "chunk" and be up and runnin. thanks for the info man, i'll definatly think its an option now.
