3.73 swap
Car: 83 Camaro duh
Engine: 355
3.73 swap
I wanted the thrill of banging through the gears in my Camaro so I looked around and found a junked 83 Firebird minus engine with a t-5 and 3.73 gears with rear disks. I currently am running 3.08 and was wondering if it will even be worth my effort to change to the 3.73 and how bad will it effect my highway drivability.
Re: 3.73 swap
Of course it's "worth it", TO ME, because it's YOUR money.
Seriously, you won't believe the difference. It'll be like a whole other car.
I doubt it will affect your gas mileage too strongly. My car came with that gear stock; it regularly got about 22 mpg highway, and 17 or so city, when new.
Car: 89 formula, 89 Cadillac Brougham
Engine: 355,HSR,patriot alum. heads,TFS cam
Transmission: 700r4, 2500 B&M stall, shift kit
Axle/Gears: 3.73 ten bolt, powertrax locker
Re: 3.73 swap
i went from 3.27s to 3.73s and it was a huge difference.
Car: 1987 Chevy
Engine: L69
Axle/Gears: 3.73 posi
Re: 3.73 swap
It isn't gonna hurt you much in mileage too much. My 87 Monte Carlo has stock 3.73s and still gets around 21 highway, so you'll be a doing a little beter than that in a lighter, more aerodynamic F-body. With a T-5 you'll be spinning just under 3 grand at 70mph with a 3.73.
It will make you much faster though. My monte's got a stock L69 & turbo 200 and can easily beat stock 305 TPI's cause it's got a 3.73 posi while most F-bodies are stuck with 3.23s or 3.08s
Car: 83 Camaro duh
Engine: 355
Re: 3.73 swap
I just finished the swap last weekend and what a difference! Only thing is now I have to save the money for limited slip to keep from roasting my cobras!
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 3.73 swap
you want a difference? i went from 2:73 to 3:73, totally different car...
hectre13
Dec 11, 2023 08:14 AM
ambainb
Apr 25, 2016 09:21 PM
