4th gen axle swap. Ebrake cable connundrum
Car: ' 91 Camaro RS (california bought)
Engine: LS6 382 Stroker..booyah
Transmission: Tremec T56
Axle/Gears: Moser 9" 3.89
I was wondering if anybody has done a 4th gen axle swap into a 3rd gen camaro. I am putting in a rebuilt 3.73 posi rear axle from a '02 camaro into my '91rs and its a bolt out/bolt in kinda job...everything lines up and bolts together without any trouble. The ONLY trouble i'm having is hooking up the ebrake cables from the 4th gen axle. The cables are too short. I was wondering if you have done the axle swap, what was your solution with the ebrake cables...how did you make them work.
Thanks for any suggestions.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 4th gen axle swap. Ebrake cable connundrum
use the search function,
this swap has been done thousands of timesand there are tons of posts about it.
edmiller is currently working on getting custom cables made for this application. look up the thread in the brake board titled "Hey ed" its 3 pages long, and it will keep you informed on the status.
ambainb
Apr 25, 2016 09:21 PM
