t56 swap...
Old May 6, 2007 | 02:35 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
t56 swap...
Im looking to convert my 700r4 to the t56. Ineed all the parts. Ive read the stickeys and what not ive done searches, ive talked with ppl that have done this swap
~if your just gona bash me,have nothing usesfull to add just DON'T i come here for advise and not to start arguments
afew questions before i start buying parts
1. anyone{ person} or website that sells a kit for this swap?
2. im also planing on converting to a ls1 when i get the money, are there any different parts i need to get ,to hook this up to this ls1 that would be different from a mostly stock 350ci?
3. any suggestions with the part i should use? like perferance? good companys vs ones i should stay away from?
4. i hear the 93-97 t56 is the one i want, the 93 i here is some ****. what year should i look for ?
5.any and all help i thank you for
im sure ill think of some other questoins after i finish this post.It's 3:30 am and abit tired from work and some other stuff but i cant sleep so finnaly decided to ask for some help for this bord
6, im not sure what my gear ratio is now ill have to look at the code..but will i want to switch em up to a higher gear ratio?
7. with me having a mecanical cable for mygagues i know i need vss or some sort of thing like that but would it just better toget new gagues that have vss and just change it from 40 to 4000 signals amin?
if you think i dont know what im talking about , chances are your right i learnbetter when ido the work and not by reading how to do it.
thanks
Old May 6, 2007 | 09:17 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Re: t56 swap...
ttt
Old May 6, 2007 | 12:49 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Re: t56 swap...
I'm fairly sure that the T-56 for the LS1 is a completely different tranny than the one for the LT1/L98, so if you got one to match your current engine, you'd have to get another one once you swapped in the LS1. (Unless it's possible to just switch the bellhousings - anyone here have an answer for that?) It might be better to just save up & swap in the LS-series stuff all at the same time...
Old May 6, 2007 | 01:33 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Re: t56 swap...
just had a question about it, so i ased nyone with any deffenet answers?
Old May 7, 2007 | 09:33 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Re: t56 swap...
common anybody?
Old May 7, 2007 | 10:42 AM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
Re: t56 swap...
I believe the input shafts are different between the LS1 and LT1 T56's. It's not just as easy as swapping the bellhousings. Basically people say you're better off getting the transmission that's correct for you motor than trying to convert one to the other.
Don't get a 93 T56. I don't know why, but everyone says not to. 94 to 97 is alright.
With the T56's double overdrive you can run 4.10's and do alright with gas mileage, so I've heard.
Old May 7, 2007 | 01:29 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: t56 swap...
With a cable driven speedo you're better off getting the aftermarket T56 from Tremec, since it comes with the tailshaft housing that works with the stock T5 speedo setup.
However it will not work with the LS1 T56 either. If you really want to go to the dark side, then do the engine and trans at once, much simpler and cheaper.
Old May 7, 2007 | 05:02 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Re: t56 swap...
" If you really want to go to the dark side, then do the engine and trans at once, much simpler and cheaper." what you mean the dark side? lol
anyways im just gona save till i get engoh money for both the ls1 and the t56 what should i look for with both? so the tremec wont work with the ls1s?
Old May 7, 2007 | 07:38 PM
AT4 T/A's Avatar
Car: 1989 IROC-Z
Engine: L98 350
Transmission: New 700r4 Done by 11/14/07!
Re: t56 swap...
I'm considering the same LS1/T56 swap for my '89 IROC, after a failed bid at a 2000 Z28. Since I'm looking for the same information as you, I thought I'd share an article I found. It sure helps me, and I hope it does the same for anyone else that reads it.
http://www.skulte.com/T56.html
Old May 7, 2007 | 11:10 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Re: t56 swap...
na ive read that before, it helped abit but not what i wanted to know
like yeh it had a list of wat parts i should get and all but like im kinda lookin for alist of the parts i need with like what brand and modle to get stuff like that cuz i dont know anything about these manual parts i would need cuz i never needed to look into it
at4 t/a if you have Instant Messanger my screen name is toxik iroc message me some time i got afew questions for ya
Old May 8, 2007 | 12:41 AM
Kevin91Z's Avatar
Re: t56 swap...
The "dark side" is the LS1 engine. Havent you heard from the Star Wars movies to "beware the power of the dark side" ? Well, you have to beware the power of the LS1. It will lead you astray and make you do bad things, like hack up a good thirdgen to install it. The LS1 is a great engine, but it doesnt belong in a thirdgen that came with TPI. I can run circles around many LS1 engines with my TPI. (and many LS1's can run circles around me.)
If you want an LS1, go buy a car that came with one. Just my opinion.
Old May 8, 2007 | 09:37 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Re: t56 swap...
ive thought about just building up my 350 ,unless im compleetly rebuilding it i dont see why i should build up motor with 140xxx on it , yeh its running kinda strong still and it would be cheaper in the short run.
yes i saw starwars im not that yong.
mabe i will buy an ls1 car and just uses it as a donnor {yes i know this isnt wat you ment.}
why would you say hack up?? is your 3rd gen compleetly stock? if im gona be doing this swap im going to make it as tastfull as possible and not a hack job
back to the topic can anyone help me?
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
Vincent135
Sep 28, 2015 10:50 PM
