upshift and downshift problem
Old May 6, 2007 | 10:05 PM
rem27's Avatar
hello,
i'm in France and i have a problem with my 700r4.
the 700r4 was just rebuilt with corvette servo,borg wagner clutch and band,corvette governor and tv sleeve modified to stay 4 at wot and i have lokar tv cable .
all gear upshift are ok ( in D or OD) when pedal gas is half throttle or wot but when the car decelerate , tranny won't downshift from 3 to 2.
i must give little gas to downshift normally in second gear...
and when i drive with very light throttle , car upshift normally from 1 to 2 at 2200 rpm but immediately after 2 upshift 3 ( car seems to stall and ' clunk clunk' noise from motor and trans because rpm is at idle in third gear ....)
i have lokar tv cable and seems to be ok at wot and car downshift normally when i flored the gas...
have you an idea ,whats the problem ?
thanks
(tranny is a 89 model and i have transgo vb separator plate)
Old May 6, 2007 | 11:38 PM
Gramps's Avatar
Car: 87 Camaro IROC
Re: upshift and downshift problem
are you sure its not the shifting but the lockup instead?
Old May 7, 2007 | 12:58 AM
rem27's Avatar
i think it's the third gear but maybe it's lockup...
if it's a luckup problem ..why lockup engage early ? ( and won't disengage...)
if i stop the car , tranny downshift normally and 1 gear engage.
my old trans had only 2 wire in valve body ( red and black on lockup solenoid)
in new trans i have 3 wire : 2 on solenoid and 1 wire on 4th clutch terminal on valve body.
old tranny is a 86.new is 89
what's your opinion ?
Old May 7, 2007 | 06:38 AM
rem27's Avatar
you have reason !
the lockup don't work well....i unplug connector on tranny and downshift and upshift are perfect.
lockup is the problem ! it's on too early ...and seems to have difficulties to disengage ..
Old May 7, 2007 | 07:01 AM
rem27's Avatar
ok i have found my computer lock the converter at 15 mph.....i think upgrade my computer and modified the lockup speed !
Old May 7, 2007 | 08:07 PM
Gramps's Avatar
Car: 87 Camaro IROC
i have the same thing happen to me. problem with mine tho is that i had mine rebuilt to handle more power, so the oil pressure went way up, and my lockup is harder to dissengage now. i have to push hard on the throddle to get it to disconnect. it will only be like that for a while, im putting a 383 in soon, but my tranny blew up, so thats where i spent my money.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
