rear question
Old May 8, 2007 | 12:18 PM
dave-92gta's Avatar
Car: 92 trans am/ 93 dodge spirit V6
Engine: L98 V8 - 350
Transmission: TH-700-R4
rear question
alright. after this winter i decided to put a bunch of money into my car fixin up the small things. so the problem: when i put the car into drive, there is a clunk. i traced it back to the rear of the car. now i thought it was a U joint but it turns out its the rear end that has some play in it. now the car only has 115,000 km or like 70,000 miles so the rear end really shouldnt have enly play. am i looking at a new rind and pinion gear set? should i not bother and get a better 12 bolt or dana or something better than my 10 bolt? any opinion is thanked. im in no rush. the car is still driveable and its not that bad i just want to fix it.
next question is about posi lube. i jsut want to know why we need to use it and what it does. jsut curious. thanks
Old May 8, 2007 | 12:19 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: rear question
clunking is 99.9% of the time a u-joint, and since they're cheap ....under $30 for both, i'd replace them first....then worry about a $800 gear swap
Old May 9, 2007 | 09:27 AM
dave-92gta's Avatar
Re: rear question
i checked the u joints. i know its the rear. when i have my car in nutral on my lift, the rear wheels move back and forth and the driveshaft stays still. i know its the rear end that has play
Old May 9, 2007 | 01:39 PM
xpndbl3's Avatar
Car: 1984 Z28
Re: rear question
some play is normal, on my 9" i can spin it back and forth as well
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
redmaroz
Aug 16, 2015 11:40 PM
