87 GTA axle
Old May 8, 2007 | 10:07 PM
philcol's Avatar
87 GTA axle
Have a 9 bolt 7 3/4" ring gear. I need a rear axle and want to know if there is a difference between the drum and disc brake axles. Or did all of these rear ends come with just disc brakes?
Old May 14, 2007 | 10:27 PM
philcol's Avatar
Re: 87 GTA axle
Can't believe no one knows. ?????????????????
Old May 18, 2007 | 01:57 PM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Axle/Gears: 3.55 8.8
Re: 87 GTA axle
They came with both disk and drums.
I am 99% sure the axles are the same. Backing plates from the 10 bolts for disks will also fit the 9 bolts.
Old May 18, 2007 | 02:04 PM
Re: 87 GTA axle
9-bolts with drums are quite rare in the US. You probably won't run across any of those.
Backing plates are different on the 9-bolt vs the 10-bolt. The hole in the center is a different size and the bolt pattern on the flange is different.
9-bolt axles also are different on the 2 sides; one side is longer than the other.
6speedIROC
16
Mar 15, 2023 08:33 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
Numbah-1
Sep 20, 2015 09:31 AM
dbrochard
Sep 7, 2015 09:41 AM
rudolphschenker
Sep 4, 2015 02:41 AM
