Converter lockup switch question
Old May 8, 2007 | 10:21 PM
SAMRS350's Avatar
Car: 1989 Camaro RS
Engine: TBI 350 - Approx 300hp
Transmission: 700R4 (Soon to be Built)
Axle/Gears: 3.73's & Eaton Posi
I read the tech article on making a switch to lockup the torque converter, and I understand that it shaves time off of a quarter mile, but I have a question, if I was to race in a quarter mile race like at a strip, and I went from a dead stop to WOT, when would I activate the switch??? like during the 1-2 shift??
any help???
Old May 10, 2007 | 08:10 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: Converter lockup switch question
You dont want your converter to lockup when your racing only on the highway.
Old Jul 15, 2007 | 10:14 AM
C.M.Jones's Avatar
Car: 84 Camaro, 90Firebird, 87Transmaro
Engine: custom 5.7, 5.0 , 6.5 Turbo diesel
Transmission: 4spd, auto, auto
Axle/Gears: 2.77 posi
what happens if you dont install the lockup switch? will it mess up the tranny/converter?
Old Jul 26, 2007 | 04:39 PM
C.M.Jones's Avatar
bump
Old Jul 26, 2007 | 04:58 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The ctock converter clutch is a little weenie thing that's only designed to hold up under cruising power. For acceleration it's supposed to be unlocked. Locking it up at WOT will kill it eventually. If you had a racing converter with a multi-disc clutch, then maybe it would be ok to leave it locked up.
Old Jul 26, 2007 | 07:01 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
so the switch should only be on(converter lock-up) cruising in fourth? i am wanting to do this but i don't want to damage it.
Old Jul 26, 2007 | 07:06 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
On while you're cruising, yes. You could lock it up in any gear except first, but it must be locked up in fourth.
Old Jul 26, 2007 | 07:08 PM
so it won't hurt it in any gear as long as i am just cruising?
Old Jul 26, 2007 | 07:32 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
As long as you're cruising or accelerating only lightly it's fine to be locked up.
Old Jul 26, 2007 | 07:47 PM
onesickss's Avatar
the converter lockup will only happen in fourth gear in OD at around 40 to 45 and is mostly for cruising. B&M makes a converter lockup kit that allows you to adjust the speed at which lockup occurs and you can also turn it on and off. as for quarter mile times I don't see that much of a difference happening ET wise.
Old Jul 26, 2007 | 09:00 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
When my turd ran low 14's, I temporarily switched to a no CC q-jet and vac-advance dist. I had a lock-up switch for the TCC and it was worth 2 tenths in the quarter and 1-2 mph. It will not lock-up the converter in first with the switch on. I would leave the line with it on and it would be locked from 2nd gear on.
Old Jul 27, 2007 | 01:01 PM
RodsRideSS's Avatar
Car: 87 Monte Carlo SS
Engine: Tweaked out 350
Transmission: tweaked 200r4
My 1987 Monte Carlo SS with a 200r4, would lockup at WOT in 4th gear...it's built into the ECM to do that.
1992 Trans Am
May 10, 2023 07:19 PM
MustangBeater20
Oct 29, 2022 09:20 PM
69 Six Pack
Oct 5, 2015 07:51 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
