t-5 and 350
Old May 16, 2007 | 05:32 PM
83-84z28's Avatar
Car: 1983 z28
Engine: '73 4-bolt 350
Transmission: t5
Axle/Gears: 3.42 with auburn and 28 spline axle
t-5 and 350
I know the t-5 wont hold too long with a 350 infront of it but should i use a higher performance clutch set or just stock type?
Old May 16, 2007 | 06:30 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Re: t-5 and 350
I think you answered your own question...
Why would you want to put a better clutch on it if you already know the tranny cant take a bit of abuse with the stock clutch?
But i guess it would already be there when you blow up that tranny and decide to replace it...
Old May 16, 2007 | 08:05 PM
83-84z28's Avatar
Car: 1983 z28
Transmission: t5
Re: t-5 and 350
my t-5 has only about 5k-8k miles on it rebuilt i'd like to get what i can out of it until i can afford a t-56 or put in an auto
Old May 16, 2007 | 11:06 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: t-5 and 350
This is the second most asked question, right after "how do I install a T56?" I used a McLeod clutch in my T5 for more than a few years. It held up fine with several drag strip passes on ET Streets. It wasnt until I started running 12's that the T5 broke. Your mileage may vary.
Old May 17, 2007 | 09:58 AM
83-84z28's Avatar
Car: 1983 z28
Transmission: t5
Re: t-5 and 350
Excellent exactly the answer i was looking for I hop it lasts as long as yours did i wont be doing to many 1/4 mile runs but i enjoy driving a stick car and cant really afford a t-56 right now
thanks
Old May 17, 2007 | 10:06 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: t-5 and 350
I have the centerforce dual friction installed in mine, and I'm happy with it. It takes less pedal pressure than the stock clutch in my GTA, and it engages very smoothly.
Old May 17, 2007 | 10:34 AM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
Re: t-5 and 350
I noticed alot of clutch slippage into 3rd and 4rth b/n 3500-4000 rpm or so even with the dual centerforce.....
89fast5oh
Sep 8, 2015 09:55 AM
90formulaVortec
Exterior Parts Wanted
Sep 7, 2015 07:17 PM
john204481
Sep 7, 2015 03:22 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
