'82 T/A tranny
Old May 24, 2007 | 11:29 PM
DR132's Avatar
'82 T/A tranny
hey...I recently found a 1982 trans am, three speed auto with a 305, pretty much all original, good condition...reverse is gone on it though...I dont know too much about their trannys, did they have 200-4r's then or were they turbo 350's? if they didn't have turbo 350s then would one bolt up fine? thanks...
Old May 24, 2007 | 11:55 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
Re: '82 T/A tranny
200r4 is a 4-speed auto, only thirdgen to get it was the turbo T/A. I think its the 200c, also used in some of the early 80's G-bodys. I don't think GM used the 350 in thirdgens at all.
Old May 25, 2007 | 12:01 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Re: '82 T/A tranny
IF that is the original tranny for the car, you are looking at a TH200C.
A short tail (6") TH350 should pop right in place of the th200. Both trannys have the exact same location on the tranny mount (22.250" from front) but the th350 will measure out overall 27 5/8" and the th200 is 28 1/4
I cant remember if both output shafts are the same size/spline or not. But if they are, then it shouldnt be a problem re-using the original driveshaft
Old May 25, 2007 | 07:57 AM
the_am_man's Avatar
Car: 82' T/A
Engine: LG4
Transmission: THM200c
Re: '82 T/A tranny
It's a 200c. I killed mine last summer and had it rebuilt. What a waste of cash, but my dad made me get it fixed. We had the tranny out of the car and when i was gone for a week he took it to Russ Moore.
$500 i could have spent towards a tranny swap gone. I wasnt happy.
If you buy it, you will definently be swapping in something else. I wish I would have known the th350's almost bolt in, i kick myself everytime I think about it.
Old May 25, 2007 | 03:57 PM
DR132's Avatar
Re: '82 T/A tranny
^^^yes...now that I know it's a turbo 200 it will definitely be being replaced...another question...will a 700r4 work also? thanks...
Old May 25, 2007 | 08:47 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Re: '82 T/A tranny
yes, but thats going to require some actual effort to do lol
The 700r4 mount is 3/4" farther back and is 1 3/4" longer overall, which will most likely require driveshaft modification/replacement
Old May 29, 2007 | 04:48 PM
The White Knight's Avatar
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Transmission: 200C 3 Speed
Axle/Gears: 2.93 Open Diff
Re: '82 T/A tranny
We had a 200c in our 83 Trans am, Reverse went on it to lol So we put in a Th350 with a shift kit.. no problems since
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
F-body-fan
Nov 4, 2015 06:13 AM
2012sergen11
Oct 13, 2015 07:38 PM
bjpotter
Oct 4, 2015 07:48 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
