PROBLEMS W/TRANSGO KIT
Old May 25, 2007 | 11:00 AM
GREEN WOLF's Avatar
Car: 1992RS CAMARO
Engine: 305TBI
Axle/Gears: 3:42
I have a 1992 camaro w/305 tbi i installed thetransgo street/strip kit w/1-2 accumalator and the vette servo,the tv cable is adjusted correctly,but now when i put it in drive it shifts fine but will not downshift when i floor it,also i have the b&m megashifter and when i try to shift manually i put it in 1st and then shift to second but it will not shift to second untill red-line,i beleive it should shift immediateley when i manually put it in 2nd or 3rd. I don't know if i missed a step in the install or what . Any help would be appreciated as this is my daily driver and i need it fixed as soon as possible. thanks,
Old May 30, 2007 | 02:59 PM
GREEN WOLF's Avatar
Car: 1992RS CAMARO
Engine: 305TBI
Axle/Gears: 3:42
Re: PROBLEMS W/TRANSGO KIT
TTT
Old May 31, 2007 | 11:32 PM
performabuilt's Avatar
Sounds like you have a TV issue , and no the upshifts will not occur exactly when you move shifter up . The kit only allows you to hold the gears down as long as you like
db057
Sep 4, 2015 07:57 AM
Mickeyruder
Sep 2, 2015 02:45 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
soarestransam
Aug 24, 2015 08:15 AM
g.l.mos
Aug 22, 2015 12:02 AM
