B&M shift improver kit or TransGo shift kit?
Old Jun 13, 2007 | 07:06 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
How many of you have experience with either of these 2 kits, and which do you prefer? Obviously there's a bit of a price difference, the B&M shift IMPROVER kit is $39.95 at Summit Racing:
http://store.summitracing.com/partde...5&autoview=sku
And the TransGo shift kit is $139.69 at Summit Racing:
Is the TransGo really worth the extra money, or will I see the same improvements in either one? Basically what I'm doing is just firming up my shifts, because 2nd-3rd and 3rd-OD are kind of sloppy, but I don't think they're bad enough to need a rebuild just yet. I'll probably toss a Corvette servo in there while I'm putting a kit in, but which one to choose?
Old Jun 13, 2007 | 07:10 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Re: B&M shift improver kit or TransGo shift kit?
Order a transgo shift kit from probuiltautomatics on the board here. Can't go wrong with that.
Old Jun 13, 2007 | 07:38 PM
BlueZee28's Avatar
I think I found a good deal on the TransGo kit. I got it on ebay for $90 shipped to my house.
Old Jun 13, 2007 | 07:44 PM
Pro Built Automatics's Avatar
The kit I carry offers more than the one that you see here. It offers smooth part throttle shifts, and the shifts get firmer with more throttle. I replace the steel check ***** with the Torlon check ***** which do not damage the separator plate. Updated Viton seals for the Corvette servo. New accumulator piston, pin and seal for the 2nd accumulator, new forward accumulator piston and seal. No out dated video, larger boost valves, etc. Go to https://www.700r4l60e.com/store/prod...&cat=28&page=1
If you have any questions on this call me in the evenings. Dana
Old Jun 14, 2007 | 06:16 PM
HP junkie's Avatar
Car: 91 Z28
Engine: l98 5.7 TPI
Transmission: 700R4,2600TCI stall,Trans Go
Axle/Gears: 3:73
How much work is requiered to install your kit?
Old Jun 15, 2007 | 02:50 AM
About the same as the regular TransGo Performance Shift kit. If you have not done one before, then you will need a few hours to do this right. You will need blue shop towels (no lint), inch pound torque wrench, files, hand drill, air, metric sockets, hand tools, etc.
Old Sep 11, 2007 | 09:17 PM
suh_wheat_86305's Avatar
Car: 1986 Trans Am
Axle/Gears: 3.23 gears
Pro Built...
stupid question for you... ever hear of optional gears? it would be cool to choose the gear ratios... or at least have some alternatives?
I will probably purchase your transo kit, linked above... and have Desert Crank install it... I see that it has the corvette servo that everyone mentions.... my car shifts really lazily. after the other upgrades, the transgo kit must be done! bu..ut... i need a kit for my 1986 TA... please advise...
Old Sep 12, 2007 | 12:19 AM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Superior or their TransGo kit IMO. B&M is a horrible approach and the result is equally bad.
J-money
Jan 4, 2019 09:45 AM
tonys91rs
Oct 10, 2015 03:31 PM
hdis2002
Sep 8, 2015 02:52 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
