Factory 5-Speed
Old Jun 28, 2007 | 05:23 PM
burnoutson's Avatar
Car: 1991 Camaro RS
Engine: 305 Mod/Tune TBI
Axle/Gears: 3.63
Factory 5-Speed
hello to all that read this. I have been a member here for some time, but never post much of anything, but now it's time for the sinking of the money into the car. so, here's my question. I have a 91 RS 305 TBI (like everyone else) and as far as i know the tranny is an M5 from what i have gathered from other sites, but needless to say, it's a 5 speed automatic. im going to be beefing up the motor and would like to know how many pony's the tranny can take. i would like to stay with it, since it is a decent 5 speed, but if it can't take over 300HP ill have to do something different. but if anyone knows if the trans. can take decent HP or no. thanks!
Old Jun 28, 2007 | 05:43 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Factory 5-Speed
M5 isn't a model of transmission, it's just an abbreviation for "manual 5 speed". The transmission you should have in your 91 is a "World Class T5". If you don't abuse it, it could last quite a while. If you beat on it though, then not so much.
Old Jun 28, 2007 | 05:45 PM
Rayvan's Avatar
Car: '89 Formula WS6 N10 No T-Tops
Engine: LB9 225HP
Axle/Gears: 3:45BW
Re: Factory 5-Speed
It's not a 5 speed Automatic.
If it's a typical 3rd Gen 5 speed Manual, you could do a lot stronger than a T5. It may last if you're easy on it, but a T56 out of a 4th Gen car would be much stronger.
Old Jun 28, 2007 | 07:16 PM
burnoutson's Avatar
Car: 1991 Camaro RS
Axle/Gears: 3.63
Re: Factory 5-Speed
OK, seems as though my translation here got a little messed up, what im asking is how much HP can a stock tranny hold up. I'm looking to build my engine to around 325HP or theres abouts. will the stock tranny keep up with that, or will i need to buy one that could hold some power.
Old Jun 28, 2007 | 07:26 PM
Synful's Avatar
Re: Factory 5-Speed
im confused, is it a manual or automatic, you said 5 speed automatic which are counter-intuitive to me.
the 88+ world class T5 manual transmissions "5 speed" can handle a little over 300 lb/ft of torque, you can whomp on one that doesn't have any problems, all day long with a stock 305 TPI and you'll be fine. TBI won't even hurt it at all. Chevy intentionally did not pair a T5 with a 350 because it didn't have a high enough torque rating for them to garuntee it not breaking under continuous and repetitive hard launching.
if its an automatic transmission i THINK its a 700r4. 700r4s can handle anything reasonable up to prob 700-800hp or torque.
Old Jun 28, 2007 | 07:33 PM
burnoutson's Avatar
Car: 1991 Camaro RS
Axle/Gears: 3.63
Re: Factory 5-Speed
well, the thing im scared of is i don't know what tranny it is to be totally honest with you. everyone sez that my car came with a 700R4, but it has an overdrive making it 5 different gears. i know the thing can take what i have right now, but what i have ain't much at the moment. if i move into the 300HP ground with that tranny im scared i might chew it up. again, if im not making any sence it's mainly because i have taken advice from people that don't know that much about the car, so i decided to take this route with people that have worked on them before. so, in any event, if i have a 5 speed overdrive automatic trans, can that take 300HP?
Old Jun 28, 2007 | 07:38 PM
Synful's Avatar
Re: Factory 5-Speed
heres just a tip of the language people are used to hearing
if your car is an automatic with overdrive you don't call it a five speed, you call it a 700r4. when you say 5 speed people immediately think T5, or 5 speed MANUAL transmission. so never say 5 speed in reference to automatic, it just trips people up, as it did earlier in this thread. they all think you have a manual tranny, when infact, you have a 700r4 automatic tranny.
700r4 can easily withstand 300hp
Old Jun 28, 2007 | 07:44 PM
burnoutson's Avatar
Car: 1991 Camaro RS
Axle/Gears: 3.63
Re: Factory 5-Speed
heres whats messing with my head though. if it's indeed a 700R4, and help me if im not hearing this right, but the R4 means that it's 4 gears correct? do i have a 700R4 overdrive?
and ill work on my messageboard lingo
Last edited by burnoutson; Jun 28, 2007 at 07:45 PM. Reason: Automerged Doublepost
Old Jun 28, 2007 | 07:49 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Factory 5-Speed
No, it has an overdrive making it four different gears, not five.
Old Jun 28, 2007 | 07:51 PM
Synful's Avatar
Re: Factory 5-Speed
yap, what he said
1, 2, D, [D]
is 700r4
Old Jun 28, 2007 | 07:55 PM
burnoutson's Avatar
Car: 1991 Camaro RS
Axle/Gears: 3.63
Re: Factory 5-Speed
ok, starting to get the picture here, but why is it when i go down the road, i can count 5 different gear changes? keep in mind that my knowlege of trans. isn't all that much, i know the basics of how they work, and believe me, i can tell you what doesn't work
Old Jun 28, 2007 | 08:00 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Factory 5-Speed
You're mistaking the torque converter clutch locking for one of the gears.
Old Jun 28, 2007 | 08:14 PM
burnoutson's Avatar
Car: 1991 Camaro RS
Axle/Gears: 3.63
Re: Factory 5-Speed
ahhhh, now i understand, tanks! at least thats one aspect of this car that makes sence to me know. tanks ya'll vary much!
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
