T5 to 4L60E?
Old Jul 1, 2007 | 05:54 PM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
T5 to 4L60E?
My T5 gave out today in my 84 Z28 and I cant really afford to have it rebuilt right now. I found a 4L60E for sale for $300 canadian and I've read that it has the same dimensions as the 700 R4. Will I be able to use this transmission with the stock driveshaft? Also, since it is the electronic version, what do I need for it to work? This isn't going to be in the car for long so it doesnt have to work great, even if I cant use the lockup torque converter itll be fine by me. Need to do something, I live on the highway and cant go to work 30 miles in first gear.
Old Jul 5, 2007 | 06:53 PM
CamaroKid89RS's Avatar
Car: 89 Camaro RS/SS
Axle/Gears: 10 bolt with 3.42
Re: T5 to 4L60E?
You're going to need the controller for it. Whether that be a PCM or an aftermarket controller. The 4L60E requires a controller for shift points and converter lockup.
Old Jul 5, 2007 | 07:00 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: T5 to 4L60E?
Forget the 4L60E and find a 4L60.
Old Jul 6, 2007 | 12:53 AM
84Z28406's Avatar
Re: T5 to 4L60E?
I can't find any 700R4 or 4L60 units around my place for less than the cost of a rebuild for my T-5. I called around and one place will rebuild it for $750 canadian, so I'm going to do that instead. I prefer shifting my own gears, the 4L60E idea was only because it was cheap. Looks like I'll be driving my S10 until I can save up $750. Just for future reference though, a 700R4 or a 4L60, would they need any sort of controller or just the automatic flexplate?
Old Jul 6, 2007 | 12:57 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: T5 to 4L60E?
Just the flexplate, shifter, shift cable, TV cable, associated bracketry, cooler lines, cooler, console top, and wiring to lock the TCC.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
Nervous2
Oct 8, 2015 10:53 PM
LSXcamaro
LSX and LTX Parts
Sep 17, 2015 11:17 PM
IROCZ1989
Sep 4, 2015 11:54 AM
f-bodyz28
Sep 2, 2015 05:03 PM
