1/2" Screw In Wheel Stud Torque
Old Jul 7, 2007 | 01:06 PM
JesasaurusRex's Avatar
Looking for torque specs for my 1/2-20 screw in wheel studs from ARP. Didn't come with any instructions so I checked on ARP's website and for a 1/2-20 fastner at 190,000 psi tensile strength, with moly lube, it says to torque down to 107ft lbs. I'm curious as to if this information is correct or not since it seems a tad high so i just wanted to know what everybody else with 1/2" screw in studs torqued their fastners to.
Also I did NOT go off ARP's torque specs for 1/2" studs because the fastner is not really a 1/2" stud, it's a 1/2" bolt. Am i correct about doing this?
Old Jul 7, 2007 | 01:09 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: 1/2" Screw In Wheel Stud Torque
are you asking about torqueing them into the axle flange? or the lug nut torque?
Old Jul 7, 2007 | 01:14 PM
Old Jul 7, 2007 | 03:56 PM
nobody has 1/2" screw in studs
Old Jul 7, 2007 | 05:14 PM
xpndbl3's Avatar
Car: 1984 Z28
race car parts buddy....
ARP opens on monday to call them.
Old Jul 7, 2007 | 05:19 PM
f*ck that, 90ft lbs with red loctite and i'm calling it a day. F*ck The World!!!
Old Jul 7, 2007 | 05:55 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
They will be a grade 8 bolt. Torque to 120 pounds.
Old Jul 7, 2007 | 06:12 PM
what will be grade 8 bolts?
the ARP wheel studs have 190,000 tensile strength...grade 8 is 150,000
Old Jul 8, 2007 | 10:28 AM
xpndbl3's Avatar
Car: 1984 Z28
get it on yet? I want to see pics.
Old Jul 8, 2007 | 11:24 AM
no, still confused
Old Jul 8, 2007 | 11:26 AM
xpndbl3's Avatar
Car: 1984 Z28
they're above grade 8 bolts so 90-107 ft/lbs is fine.
redmaroz
Apr 25, 2017 07:14 AM
italiano67
Dec 11, 2016 09:21 AM
deracer
Apr 11, 2016 12:04 AM
camaro71633
Sep 1, 2015 10:24 AM
Dialed_In
Aug 20, 2015 01:45 PM
