weird noise when lane changing and cornering left
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
i recently ahd a used posi 323 rear end installed in my car. when i first got it back i would get a rubbing/grinding(sort of) noise from my right rear tire when changing lanes left at highway speeds and while cornering left at moderate to high speeds. the noise has slowly gone away since i got it back about 3 weeks oir so ago. but it still persists when cornering really hard left.(i travel realy tight turning roads). any ideas what it is and if i should be worried that its gone away for the most part.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: weird noise when lane changing and cornering left
A worn bearing might be the culprit.
JamesC
JamesC
Car: '92 RS
Engine: 357ci
Transmission: G-Force t-5
Axle/Gears: 4.10 10bolt mini spool
Have you had the car on an alignment machine?? rearend may be out of center. Check for signs of rubbing inside the fenderwells.
maroe624
Apr 16, 2017 08:29 AM
Thornburg
Aug 25, 2015 01:46 AM
