9" rear end
Old Jul 19, 2007 | 01:58 PM
urmomshot77's Avatar
Car: 83 camaro
Engine: 383 stroker
Transmission: TCI 3spd manual
9" rear end
Does anyone know of a direct bolt in 9" rear end for a 3rd gen Camaro with Coils (not leaf springs)?? Any links would be help alot, thankyou.
Old Jul 19, 2007 | 02:08 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: 9" rear end
Sure!
Moser
Strange
Spohn (I think he sells moser stuff)
You've got $3000 burning a hole in your wallet?
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
Transmission: G-Force t-5
Axle/Gears: 4.10 10bolt mini spool
Re: 9" rear end
Moser Engineering has a direct replacement for us. Can get pieces or entire unit. I think an entire unit (housing,axels,center section,gears,posi) will run $2500 ish
http://www.moserengineering.com/Page...gaxlepack.html
Old Jul 19, 2007 | 02:20 PM
Car: 83 camaro
Engine: 383 stroker
Re: 9" rear end
Thanks alot for your help guys. Ill be going through Moser most likley. And yeah SONIX, i put wayyy to much money into my camaro last year lol. Im gunna limit myself to a 10 grand budget for this year, so with 3grand on the rear end, ill be down to 7g's left on the camaro project and its gunna be done for good after all this.
Old Jul 19, 2007 | 06:12 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 9" rear end
i need a 9" too, so if you want to buy me one while your at it i would appreciate it, thanks .
Old Jul 19, 2007 | 08:44 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: 9" rear end
currie enterprises also makes 9" rears...
oh ya, i'll be surprised if you actually stop after 10k.. thats what i said after i hit 25k.. still has a stripped interior from when i put the cage in, no head unit for the sound system, paintjob is starting to chip in some places, and i'm getting ready to rebuild my motor again.. this hobby is just awesome
Old Jul 19, 2007 | 10:24 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 9" rear end
I've had my car since 1999. I don't want to even think about how much I've invested in it in 8 years. It also started out as a mismatched parts, 15 second street car that I got down into the low 14's during the first race season.
If money is no object than you can easily buy a direct bolt in from any of the suppliers mentioned above. If you're trying to do it on a budget, you can buy the housing with axles for around $1000 then pick up your own center section from the junkyard or local swap meets.
Old Jul 20, 2007 | 06:10 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Re: 9" rear end
Just be aware that Moser customer service sucks should you have problems with the rear.
Old Jul 20, 2007 | 06:52 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Re: 9" rear end
Lot of guys have problems with gear wine to with moser, mine is friggin loud inside the car. Also plan on buying a break setup to when you order unless your good at moddifying.
Old Jul 21, 2007 | 02:50 AM
Car: 83 camaro
Engine: 383 stroker
Re: 9" rear end
5678 TA: Yeah its definatly an addicting hobby. I like 3rd gens cause of all the stuff you can do to them. The downside is that everything is made weak as hell on them cars. I put easy, 14k into mine last year, and im running out of stuff to do to it. I still dont know how you spent 25k unless your breaking **** left and right.
Stephen 87, That car is sick. I cant say i have seen to many 3rd gens move that quick. Ill be happy if i hit 11.5's. Thats about my goal. .
For everyone else, ill have to look into that noise problem with that moser rear end. Its probably just the way the gears are cut though. Thanks for the heads up
Old Jul 21, 2007 | 03:31 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Re: 9" rear end
There's always a 12 bolt too, i cant see you're combo breaking that easily. Right now exotic performance plus has them on sale for like 1800 fully built with a spool and steel cover, add another 3-400 for aluminum cover, and posi unit.
edit: they have a sale right now full spooled 9" with iron case , up to 35 spline axles bare metal and 1350 yoke for 2250 free shipping!!!..add 155 for aluminum case and 250 for powdercoating if you want... not bad at all!
Old Jul 23, 2007 | 05:10 PM
proxemics's Avatar
Car: 87 Z28
Engine: 383
Transmission: th350
Axle/Gears: ford 8.8
Re: 9" rear end
http://store.summitracing.com/partde...5&autoview=sku
Old Jul 23, 2007 | 07:25 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: 9" rear end
Originally Posted by urmomshot77
5678 TA
Read my thread in the racing forum about the car being deadly consistent but the driver isn't.
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
