what stock rear end gears in 86 transam?
Old Jul 22, 2007 | 02:08 AM
86birdman220's Avatar
Car: '87 Camaro irocz
Engine: 5.7 TPI
Axle/Gears: 3.27 limited-slip
Its a 86 firebird transam, had a v8 305 and 700r stock... not posi
wondering if someone knows what rear gears this car normally had in it
i want to look myself but always forget to when i have time
appreciate any help
Old Jul 22, 2007 | 02:32 AM
86firebird350's Avatar
Car: 91 GTA
Axle/Gears: stock
Re: what stock rear end gears in 86 transam?
check the tech data on this site.
Old Jul 22, 2007 | 11:29 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
imy 86 ta had the lg4 305, 700r4 and 2:73 open rear
Old Jul 22, 2007 | 11:44 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Looking is the only real way to tell. When you get time and remember, jerk the diff cover and look--and you might consider changing the fluid.
The numbers are stamped on the ring and pinion:
41 : 15 = 2.73
40 : 13 = 3.08
42 : 13 = 3.23
41 : 12 = 3.42
41 : 11 = 3.73
JamesC
Old Jul 22, 2007 | 11:55 AM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Axle/Gears: 9 BOLT/ 3.27 GEARS
jack up the rear of the car, chock the front wheels, set the parking brake, and put it in neutral. Make a mark with chalk on a tire and the driveshaft. rotate the tire one full revolution and count how many times the driveshaft turns. If the driveshaft turns roughly 2.75 turns, you have a 2.73 ratio. If it turns about 3.25 times, you have a 3.23 gear etc. etc. This is probably the easiest way to check Your ratio.
Old Jul 22, 2007 | 02:42 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
If you set the parking brake, you wont be able to turn the rear wheels very easily.
Old Jul 22, 2007 | 06:57 PM
Engine: 5.7 TPI
oh man, it has 2.73s.
305 + 2.73s = instant win? lol
yeah no wonder why this car launches like a school bus from a tar pit.
so what should i put in it? 3.73s? higher?
i want it to be as fast as possible at lower speeds like 0-60, maybe destroy a tire every if i feel like it. it doesn't go on the highway much, and gas milage is no concern. and i'd get a posi if i had that much money right now.
like i said its a 305 though... its slightly better than stock, it has a cam and intake, im gonna get a real engine sometime soon
till then, would a gear change like this help me out? i mean, the way it is now this car is unbelieveably slow from the start, it feels like i get better acceleration around 80-100 then anything and thats not what i want
thanks everyone
Old Jul 22, 2007 | 08:41 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
3.73 would be a great gear coupled with the 700R4's 3.06 first gear.You will need to change the carrier as you have a 2 series carrier and need to go to a 3 series.So this would be the best time to change to an good grade posi unit.Dot it once and be done with if you can.
Old Jul 22, 2007 | 09:10 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
you dont have to change the carrier, you can get 3:73 gears that are made to work with the 2 series carrier
Old Jul 22, 2007 | 10:47 PM
Engine: 5.7 TPI
Ok maybe i will just get a posi then, while i'm doing this
This brings me to more questions though, like what parts do i get? lol
How can I make sure everything will fit? Like I know my rear end is a 10 bolt, but thats about it. I see there are items to fit a 10 bolt 7.5 and a 8.5 as well. Is that the diameter, so I can just measure it to check?
And then I see there can be either 26 spline or 28 spline. I have no idea what this is. How can I check which mine is?
So what I need to get is the posi carrier, the gears, and an installation kit right?
And yes I have a good mechanic to hook it up
Also, while I remember, the rear end has been making a slight klunk noise when turning... is that bad bearings or what
Old Jul 23, 2007 | 05:46 AM
JamesC's Avatar
I see there are items to fit a 10 bolt 7.5 and a 8.5 as well. And then I see there can be either 26 spline or 28 spline.
You have a 7.5. It has 26 splines.
JamesC
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
mizz0313
Aug 12, 2015 06:45 AM
