ls1 t56 swap
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: ls1 t56 swap
the ls1 trans is a t56, no?
are you referring to the hydraulic throwout bearing? sure it can be done.
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
Re: ls1 t56 swap
you can get an adaptor plate to fit it to a t5 or a muncie bell housing and use a 26 spline clutch disc.
Re: ls1 t56 swap
I think some people recommend a longer pilot bushing, you can search for posts about the ls1 t56 swap. The LT1 t56 requires using the LT1 clutch, hydraulics, and bell housing. If you already have a t5, the ls1 t56 is the better way to go.
I've seen the two different bell housing adapters on ebay with the throwout bearing retainer included.
Car: 85 camaro z28
Transmission: auto to manaul
Re: ls1 t56 swap
in the tech pages, under 6 speed swap. it say's you will need to replace the input shaft as well as the front cover of the transmission case for the ls1?
ambainb
Apr 25, 2016 09:21 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
