Jumping
Old Jul 24, 2007 | 08:59 PM
Crazy 84 Z28's Avatar
Car: 1984 Z28 Camaro
Engine: 305 H.O. 72,000 original miles
Jumping
I drive an 84 z28 camaro 305 engine with a 700r4 tranny. How do you replace the universal joint.
Old Jul 24, 2007 | 09:43 PM
TUNGSTEN's Avatar
Engine: 355
Axle/Gears: 3.73 Trutrac
Re: Jumping
Asking that question suggests that you don't have the tools or the know how to do it. It is easy once someone SHOWS you how to do it with the right tools. I suggest pulling the drive shaft and taking it to a place to have the UJ's put in for you. I have replaced many and still get frustrated when replacing them.
Old Jul 24, 2007 | 10:38 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Jumping
And you named this thread "jumping" why?!?
You need a torch to heat it up and ooze out the snake like nylon. It's a little weird the first time. Between that, a hammer and the right sized socket (doubt you have it), it's fairly easy - if you've done it before.
BE AWARE - the smell once you get all the nylon out and the melting grease hits you, be very scared of this smell.
db057
Jan 10, 2020 08:55 PM
RS Reaper
Oct 17, 2018 07:52 PM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
86White_T/A305
Mar 6, 2016 01:48 PM
RedLeader289
Sep 23, 2015 06:50 AM
