what trans fluid
Old Jul 28, 2007 | 01:52 PM
blackandgoldl69's Avatar
Car: 1984 camaro z28
Engine: L69 H.O
what trans fluid
what trans fluid can i put in with the stock fluid in my 1984 700r4 trans.can u even buy the stock trans fluid and if so whats it called
Old Jul 28, 2007 | 02:55 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Re: what trans fluid
The owner's manual for your '84 would call for Dexron ll but that's been superseded by Dexron lll(there's a lV,V and Vl I believe but read the label as to what is compatible).
Old Jul 28, 2007 | 03:13 PM
Engine: L69 H.O
how do you go about adding more trans fluid i know you have to check it while running in park is it the same for putting the fluid in.
Old Jul 28, 2007 | 05:27 PM
Grasp bottle. Remove top. Locate bottle above fill tube, using funnel if necessary. Invert bottle.
Dexron ANYTHING is compatible, they just keep updating the spec. The newer fluids work in the older transmissions just fine.
Old Jul 30, 2007 | 04:31 PM
Shagwell's Avatar
Car: projects.......
all things said if you don't know if/when the trans fluid and filter has been changed, you probably should change it, not just add more.
- and again - sofa you've got a major grasp of the obvious. Everytime I turn around I'm laughing my but off at something you're saying....
Old Jul 30, 2007 | 05:28 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Actually, I saw sofa in Vegas last year--he was packing them in at the Bellagio. Later, he was signing autographs at CarQuest .
JamesC
Old Jul 30, 2007 | 10:55 PM
Engine: L69 H.O
im only adding more and not changeing it because there isnt any but a super tiny drop on the end of the dipstick so there isnt any to change.and i was just asking if there was a certain way it had to be put in like with the car running or something.if your on this board and dont know how to open a bottle of trans fluid you shouldnt be here.
Old Aug 1, 2007 | 12:33 PM
Arctic White 91 RS's Avatar
Car: 91 RS/ 99 T/A/ 72 Vette/ 02 Z28
Engine: LSx/ Dart400
Transmission: M6/ M6/ TH400/ 4L60E
Axle/Gears: 4.10's / 3.08/ 2.73
Black, a 700R4 takes about ten quarts of transmission fluid to fill up the tranny and the torque converter. If your seeing fluid on the tip of the stick, you still have around eight or so quarts in the transmission & converter, most likely. Your probably only a quart or quart and a half low. If the transmission fluid and filter hasn't been changed, this is a good time to do it. The Dextron II or III should be fine as other have said.
Don't wait until the transmission starts to slip or the fluid gets that scorched scent to change the fluid. I switched my 700R4 over to Mobile 1 Synthetic ATF at 165,000 miles. That was the very first change my 700R4, ever got.
Currently, the car has 286,000 miles on it. Same transmission, no rebuild etc. I have tranny fluid changed about every 25,000 miles. I think a big part of why my 700R4 has lived for 286,000 miles is the frequent fluid changes, it got after 165,000 miles. I think the ole 700R4 will make to 300,000 miles...
Old Aug 1, 2007 | 10:47 PM
coolram62's Avatar
Engine: LU5 305 CFI
To check the fluid on most automatic transmissions,700R4 included,it's best to check with the fluid warm(10 minute or so drive)with the trans in park with the motor running.
maroe624
Apr 16, 2017 08:29 AM
LittleFranks
Sep 17, 2015 12:22 PM
spaigo
Aug 21, 2015 07:46 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
