help me pick a gear
Old Aug 1, 2007 | 06:54 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
help me pick a gear
Right now with my 700r4 and 3.27 gears the car goes through the traps at 4100rpms what gear would i need to go throught at 5000-5500 rpms? 3.73's or 4.10's? My car has a tire diameter of 26.0 if it helps.
Old Aug 1, 2007 | 07:32 PM
redliterunner's Avatar
Car: 89 IROC convert.
Engine: tpi 305
Axle/Gears: 3.42 10 bolt
Re: help me pick a gear
4100 rpm/3.27=1253.82
1253.82 x 3.73 = 4676.75 rpm
1253.82 x 4.10 = 5140.67 rpm
All else being equal 4.10s should put you through the traps at 5140 rpm.
Of course all else won't be equal, but 4.10s should give you what you want with a little room to grow.
Old Aug 2, 2007 | 09:32 AM
StreetRoc85 350's Avatar
Car: 88 IROC
Transmission: Pro 5.0 shifted T56
Axle/Gears: 10 bolt 3.73 posi
Unless you only want to drive it at the track i wouldnt put anything bigger than a 3.42 behind a 700R4. I have 3.73s and a T-56 and even with 2 more gears to play with its still a bit tall for my liking. 1st gear is a joke, 2nd is a smoke show, and by 3rd it starts to settle down. When i had my 700R4 in there i was turning about 3500-4000rpm on the interstate. Waaay to much for a daily driver. Esp with gas prices today.
I think some 3.42s would suit you quite well. After all TPI is a slug after 4500rpm anyway.....
My mistake i just saw that youre running a carb!
Last edited by StreetRoc85 350; Aug 2, 2007 at 09:33 AM. Reason: Automerged Doublepost
Old Aug 2, 2007 | 10:33 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
the car is a carb
Old Aug 2, 2007 | 10:52 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
with more gear, you will pick up speed.. most likely in your case.. i picked up 3mph switching from a 3.89 to a 4.30.. but then again, the pick up was with switchin from drag radials to slicks and a tad higher jetting..
i would say for you, go 3.73's.. unless your car pulls to your redline (5500), then go 4.10..
Below Average J
Members Camaros
23
Nov 18, 2015 10:03 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
camaro71633
Sep 1, 2015 10:24 AM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
