gears swapping 3:08 to 3:73
Old Aug 1, 2007 | 11:24 PM
jrocks619's Avatar
Car: 1991 camaro rs
Engine: 305 TBI
Transmission: 5 speed
Axle/Gears: 3:08
What i need to know is if anything but the ring and pinion has to be changed to go from 3:08 to 3:73 gears? i was going to go with 4:10 but i have to drive it 25 miles to school so 3:73 it is ANY HELP WOULD BE GREATLY APPRECIATED
Thanks Jerry
Old Aug 2, 2007 | 03:00 AM
ede's Avatar
ede
Re: gears swapping 3:08 to 3:73
depends on the carrier and the gears you use. if you use gears to fit the carrier basically nothing else needs changed but you'll still need a space or crush sleeve plus seals, bearings, and oil.
Old Aug 2, 2007 | 10:22 PM
jrocks619's Avatar
Car: 1991 camaro rs
Engine: 305 TBI
Axle/Gears: 3:08
Thank you do the bearings need to be pre packed or are they in the rear itself and just use gear oil?
Old Aug 2, 2007 | 10:54 PM
hgffrank's Avatar
Car: 83 Trans Am
Engine: LT1 350
Transmission: 5 Speed manual
Axle/Gears: 3.73 10bolt till it breaks
Your speedometer will not be right, but I'm sure you probably already know that.
As far as the carrier bearings, they are not packed, and are lubed by the rear end gear oil.
Plan on running around 3000rpm at 80mph.
1984HO
Mar 19, 2021 11:59 AM
InfinityShade
Aug 22, 2015 08:00 PM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
