A4 to 6 speed swap
Old Aug 1, 2007 | 10:14 PM
chevyman7106's Avatar
A4 to 6 speed swap
I was wondering where I could get a conversion kit for this type of swap. I have a 6 speed tranny out of a 2000 Firebird and am going to attempt to put it in an 86 Iroc, if anyone has any info on where I can get this kit please let me know. Thanks.
Joshua
Old Aug 1, 2007 | 10:19 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Re: A4 to 6 speed swap
Check in the tech articles.It`s there,I`ve read it.
Old Aug 8, 2007 | 03:37 PM
Thanks for the info.
Old Aug 9, 2007 | 11:55 AM
vbMike's Avatar
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
The 6 speed from a 2000 will not fit. The input shaft is longer I believe. It can be made to work if you swap out the shaft but that is a pain. You would be better off starting with a 6 speed from a 93-97 camaro.
gta90
Sep 15, 2015 04:00 PM
Keith5
Aug 27, 2015 04:37 PM
nuggie
Aug 25, 2015 01:27 PM
InfinityShade
Aug 22, 2015 08:00 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
