T5 Problem
T5 Problem
I'm grinding when I got in reverse with my T5. It doesn't do it in any other gear. It's not very loud but I get a definite vibration in the shifter handle. The only thing I've done to the car recently it replaced the master/slave although it was working properly after this repair.
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: T5 Problem
are you grinding when you are in gear?? or grinding when you are puting it in gear??
my trans grinds sometimes.. i just put it into first, to stop the gears, then throw it in reverse..
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Re: T5 Problem
your reverse sycro is bad
edit: the info above is incorrect
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Re: T5 Problem
eventually you will lose reverse. how hard is it? it depends on your mechanical skills. it involves removing the tranny and taking the tail housing out , and replacing the sycro. it should not take more the than 1 hour (if you have the tranny off the car).
Re: T5 Problem
The T-5 DOESN'T HAVE a reverse synchro.
For that matter, NO manual transmission introduced before about 1990 did. None of the old 3-speeds or 4-speeds for example. The first trans I know of that has that, is the T-56.
If all that's happening is that you're grinding the hell out of it when you put it into reverse, stop doing that; and do it the way everybody has been putting transmissions into gear since ..... well, since transmissions were invented.
Put it into a forward gear - in the case of the T-5, ANY forward gear will do - before putting it into reverse. That will stop everything from spinning in there, and you won't destroy reverse gear and fill the fluid up with metal chips, like you're doing by just jamming it into gear and listening to it grind.
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Re: T5 Problem
I was trying to trick him j/k . well I know for a fact that my t56 has a reverse sycro, and i thought t5 would be the same thing. Oh well, you learn new things everyday
Re: T5 Problem
Ok... I'm a total noob with manual transmissions so I need this broken into baby language. Before going to reverse I should put the trans in 1st. Do I need to let off the clutch and actually move the car or is it enough to just move the shifter?
Re: T5 Problem
No, you don't have to move the car; just put the trans into any forward gear (since in the T-5 they're all synchronized and won't grind, unlike reverse) to stop the guts from spinning, THEN put it into reverse. When you do it that way, the gears won't be spinning inside there when you try to shift into the unsybchronized gear, so they won't grind.
