shifting
Old Aug 8, 2007 | 01:13 PM
steve87iroc's Avatar
Car: 1987 iroc z
Engine: 355 dart platinum 215cc heads
Transmission: <<BLOWN UP TH400>>
Axle/Gears: 10 bolt 4.11's
shifting
i just got ny th400 put in my car and when ever i try and shift it myself when i put it in first i get to like 5000 rpm and it shifts by itself i thought it was the shift cable not back far enough but thats not it can there be anything else that would make it shift by itself does the vacuum hose have anything to do with it. i have it hooked up just woundering what it does thanks.
Old Aug 8, 2007 | 01:17 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: shifting
A stock transmission will shift at redline, regardless of the position of the manual shaft.
Old Aug 8, 2007 | 01:24 PM
Car: 1987 iroc z
Re: shifting
even if i put it in first i had no problem with this with my other trans my shift point is going to be around 6200.
Old Aug 8, 2007 | 01:39 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: shifting
Even if you put it in first. Play with the governor to raise you shift point, or put a TransGo shift kit in to eliminate that behavior.
Old Aug 8, 2007 | 02:44 PM
Car: 1987 iroc z
Re: shifting
can i just remove the govoner does it do anything other than set the shift point this is a race car only and am not driving on the street.
Old Aug 8, 2007 | 04:16 PM
Shagwell's Avatar
Car: projects.......
Re: shifting
if it is a race only car, then switch to a manual valvebody. Otherwise, recalibrate the governor to shift at the rpm you need.
Old Aug 8, 2007 | 05:47 PM
Car: 1987 iroc z
Re: shifting
how do you recalibrate it using smaller springs. i probbly will get the valve body later on but just want to understand alittle more.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
