4th gen rear end
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: 4th gen rear end
you only need the rear end and the same offset wheel as a 4th gen,you will need E-brake cables from a 90-92 disc set up,if you use an Ls1 rear you will need to fab your own e-brake set up.i used a combo of 3rd and 4th for my TA
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
You need a jack, pair of jackstands, sockets and ratchets (impact makes it much easier), PB blaster, 11mm wrench.
Car: '88 Trans Am
Engine: 5.7L TPI
oh dang zepher!
i forgot the jack and jackstands!
on a serious note please,please be carefull we lost a member of the sy/ty com.due to his syclone sliding off the stand,pay close attention to where you place the stands
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i made one in the FAQ section but it should be here
its pretty good but more mild details could be added
https://www.thirdgen.org/forums/faq-...-gen-rear.html
Car: 1987 Z28
Engine: 355
thanks for the help... but also some of the rear ends come with traction control is there any way to by pass that or just up and eliminate that all together?
Car: 89 Iroc-z
Transmission: TH400
just leave it there and dont use it. thats what i did. just run the non traction control (3 channel) style brake lines on the rear.
1992rs/ss
Jan 31, 2025 05:10 PM
hectre13
Dec 11, 2023 08:14 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
AkDrifted
Aug 17, 2015 07:45 PM
