ls1 t56 adapter to 5.0 motor
Old Aug 12, 2007 | 08:50 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
i see they make a ls1 trans adapter to our motors. has anyone does this swap, it it worth it? http://www.thegearbox.org/catalog/it...17/4803441.htm
Old Aug 13, 2007 | 07:12 PM
jayk2k3's Avatar
Car: 85 camaro z28
Re: ls1 t56 adapter to 5.0 motor
no one has tryed it?
Old Aug 13, 2007 | 09:07 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
why would you adapt the ls1 type when a lt1 type bolts right up?
plus, it doesn't say bolt up the ls1 type....it says bolt up a t56. means you probably need the lt1 input to do it. the plate allows you to use the existing bell housing that you have as well as the clutch hydraulics. when most decide to go for the t56, they get everything out of the donor car except the crossmember which is not a factory piece to put a t56 into a thirdgen.
if you are going from an auto to a manual, this plate does you no good anyway since you need the bell housing and everything else.
Old Aug 14, 2007 | 05:53 AM
jayk2k3's Avatar
Car: 85 camaro z28
oh ok. thanks 4 the info
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
86White_T/A305
Aug 17, 2015 12:16 AM
reiderz iroc
Aug 13, 2015 04:57 PM
Elliswon
Aug 10, 2015 12:33 PM
