700r4 no 3rd? problem
Old Aug 13, 2007 | 05:09 PM
dcboyz4eva's Avatar
Car: 01 gti, and 89 irocz
Engine: 355cu
Axle/Gears: 373
ok so i have a 700r4 with a 373 rear 89 camaro z28 its been changed over from tpi to carb...my problem is the tranny wont go into 3rd or od. if i manually shift it or put it in drive it goes 1st then 2nd then it like goes into neutral, i dont have the cable hooked up to make it downshift so i dont know if its that or fluid or something is blown in the tranny but anyyyy help is greatly apreciated. thanks
Old Aug 13, 2007 | 09:14 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: 700r4 no 3rd? problem
well, since you don't have the cable hooked up, that is probably what caused you to toast your 3/4 clutch pack. now ya get to rebuild the tranny. that cable is more for throttle pressure in the tranny than it is for kickdown. without it tranny's die a quick death....as you have found out.
Old Aug 13, 2007 | 09:16 PM
dcboyz4eva's Avatar
Engine: 355cu
Axle/Gears: 373
haha shittt o well we have 3 more..thanks for the info though
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
neekolzun
Aug 24, 2015 04:59 PM
tricky1
Aug 23, 2015 01:17 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
