t5 to t56
Old Aug 15, 2007 | 11:37 PM
89bluirocz's Avatar
Car: 1989 Iroc-Z
Engine: 350 tpi
Transmission: Swapped in T5
t5 to t56
ok well my t5 is screwed.
i have a stage 2 clutch and a lightweight flywheel that i would like to keep.
will they work with a t56 out of a lt1?
some people say yes. some say no.
help.....
Old Aug 15, 2007 | 11:40 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: t5 to t56
Well i hear you must use the LT1 flywheel, but i also hear you can use a adapter(2inch) and retain the better slave cyl. and would be ok(i have looked and cannot find this spacer by itself).
HTH
Old Aug 16, 2007 | 09:31 AM
Re: t5 to t56
No you cannot.
The LT1 clutch pulls instead of pushes.
There's no provision in the BH for the familiar style of clutch, and the flywheel is a different thickness and bolt pattern for the clutch. The stock LT1 flywheel will work on your 86-up crank.
Old Aug 16, 2007 | 08:01 PM
89bluirocz's Avatar
Car: 1989 Iroc-Z
Engine: 350 tpi
Re: t5 to t56
No you cannot.
ok so i cant use my clutch or flywheel. that sucks.
so if i can get just the transmission from this guy....
what all else am i going to have to buy?
Old Aug 16, 2007 | 08:06 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: t5 to t56
aftermarket crossmember. I dont know about the driveshaft
Old Aug 16, 2007 | 08:37 PM
89bluirocz's Avatar
Car: 1989 Iroc-Z
Engine: 350 tpi
Re: t5 to t56
i knew about the cross member but the drive shafts are the same
Old Aug 16, 2007 | 09:12 PM
Re: t5 to t56
Drive shaft is the same.
You'll need hydraulics also. And a shifter.
Old Aug 16, 2007 | 09:42 PM
89bluirocz's Avatar
Car: 1989 Iroc-Z
Engine: 350 tpi
Re: t5 to t56
comes with factory hurst shifter?
what hydraulics?
im young and new to this kinda thing.
Old Aug 17, 2007 | 01:07 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: t5 to t56
No you cannot.
Yes, there are places that sell a spacer with a T56 to retain the T5 bell housing and will allow the use of the T5 clutch assy. and retain the stock slave.
Old Aug 17, 2007 | 12:47 PM
89bluirocz's Avatar
Car: 1989 Iroc-Z
Engine: 350 tpi
Re: t5 to t56
ok so if i get that spacer i can use all my T5 stuff? except the cross member.
Old Aug 18, 2007 | 10:02 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: t5 to t56
Yep, i had hell looking for it, i found it available WITH a t56, but not by itself, that was just searches, i made no phone calls.
Old Aug 18, 2007 | 10:17 AM
89bluirocz's Avatar
Car: 1989 Iroc-Z
Engine: 350 tpi
Re: t5 to t56
ok well i found a couple of sites that sells the spacer alone. $190 was the cheapest. but i guess it will be worth it cause it will keep me from having to buy a new flywheel and clutch and everything.
Old Aug 18, 2007 | 11:53 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: t5 to t56
PLEASE tell me where!!! I wish to retain the better clutch setup.
Old Aug 19, 2007 | 01:31 PM
89bluirocz's Avatar
Car: 1989 Iroc-Z
Engine: 350 tpi
Re: t5 to t56
http://www.thegearbox.org/catalog/it...17/4803441.htm
thats the one i found and Summit sells one from McLeod Ind.
Old Aug 19, 2007 | 11:43 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: t5 to t56
SWEET, the one i found sold WITH the T56 was set to move the trans back about 2 inches.
Old Aug 19, 2007 | 11:57 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: t5 to t56
It does move the trans back 2" and you can't use it unless you have the long input shaft. The LT1 trans does not have it. (the long input) It comes in the aftermarket replacement trans. That's what the adaptor is for.
Old Aug 21, 2007 | 01:42 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: t5 to t56
Well, it looks like a simple thin plate, it doesnt look like it moves anithing back verry far, the one he found. The one i found is thick, 2 inches thick, i will email them for details.
Old Feb 25, 2008 | 10:52 AM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
Re: t5 to t56
i will make it easy on you and sell you my t5 pm me if you are interested.
Old Feb 25, 2008 | 11:08 AM
userchemical's Avatar
Car: 1984 Camaro Z28
Axle/Gears: 4th gen auburn 3.42 disc
Re: t5 to t56
make sure you dont by an lt1 flywheel. Lt1's are externally balanced on the flywheel, and your motor is balanced internally. so bolting an lt1 flywheel to your motor will send it out of balance and you'll have vibrations.
Ive done auto to t5 and t5 to t56 swaps. learn from experience, i also recommend the spec stage 3 clutch.
Old Feb 25, 2008 | 11:50 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: t5 to t56
Well, i thought the LT1 flywheel was ballanced the same as any 87+ 350, how is everyone using the T56 from a LT1 behind a TPI or any other SBC without the flywheel that must be used to retain the LT1 clutch setup?
Old Feb 25, 2008 | 12:02 PM
Re: t5 to t56
i dont know what block he is using, could be GEN1, i cant say i read ever post in here before i commented
Old Feb 25, 2008 | 12:19 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: t5 to t56
Well, i hope he is using a 87+, i have no idea which flywheel he could use to go T56 on the 85-. Guess he would HAVE to use the adapter and keep the T5 bellhousing.
Old Feb 25, 2008 | 12:22 PM
Re: t5 to t56
centerforce makes a flywheel for just such situation. you can but it on summit.
http://store.summitracing.com/partde...0&autoview=sku
Old Feb 26, 2008 | 08:38 PM
Car: 88 IROC
Re: t5 to t56
that wont work bro... i think t56 has to have 153 teeth
Old Feb 26, 2008 | 09:13 PM
Re: t5 to t56
wrong flywheel
http://store.summitracing.com/partde...7&autoview=sku
Old Feb 26, 2008 | 09:23 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: t5 to t56
Sais small/big block, that doesnt make sence, i thought they were ballanced way different? Guess it is because it might be for all internal bllanced?
Old Feb 26, 2008 | 10:05 PM
Re: t5 to t56
85- balanced internally, so you cant use the lt1 flywheel, you need this.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
