Shift kit + stall convertor installation price
Old Aug 16, 2007 | 03:28 PM
namenottakenyet's Avatar
A local shop quoted me $300 to drop transmission and 2-3 hours of installation at $60 per hour to install transgo reprogramming kit, corvette servo, .500 boost valve, and a new stall. Does that like a fair price, around $500 labor. None of the prices include the parts which I am buying seperately but they do guarentee their work, but not the parts...
Old Aug 16, 2007 | 03:34 PM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 10 bolt Richmond 3.73 posi w/ discs
Re: Shift kit + stall convertor installation price
Sounds about right. $60/hr is a cheap shop rate compared to what I saw last ($85/hr in Birmingham). So basically 2.5 hrs to drop the trans, 2.5 hrs to install the trans back in the car and 2-3 hours to install the parts.
Old Aug 16, 2007 | 03:44 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If it takes them 5 hours to R&R a transmission, I'd find another shop.
Old Aug 16, 2007 | 07:11 PM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Ditto. Dropping the tranny dosn't take two and a half hours, nor does installing it. And a B&M Shift Kit (can't speak for a Trans-Go) can be installed by yourself, while the car is on jackstands, in a parking lot. Trust me. I know. Also, I've read that you can install the vette servo without dropping the tranny, and the boost valve can be changed while you do the shift kit. The only thing you *need* to drop the tranny for is the new TC, and it doesn't seem like it'd be all that difficult. Might need a taller set of jackstands. :P
Old Aug 17, 2007 | 09:54 PM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
They're probably looking at the shop manual that tells them how long it takes to remove and reinstall a transmission for that year model car. Most all shops do that just like the dealer whether it takes them that long or not.
Old Aug 18, 2007 | 01:08 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's still only about 2 hours by the book, IIRC.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
italiano67
Dec 11, 2016 09:21 AM
TreDeClaw
Aug 14, 2015 06:58 PM
dhonda200
Aug 11, 2015 11:50 PM
drathaar907
Aug 6, 2015 04:20 PM
