Shift cable help
Old Aug 20, 2007 | 10:22 AM
Larry Dunlap's Avatar
Car: '91 Formula
Transmission: TH350 built
Shift cable help
I have a plastic press fit connector on the end of my shift cable that connects the cable to the transmission shift lever. It came off and now wont stay on. Is there a locking ring or piece or does it just press on? How would I change the plastic piece, get a whole new cable. I put a bolt with two nuts against each other to hold it now, but the shift action feels a littel weird.
Old Aug 24, 2007 | 03:56 PM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
Re: Shift cable help
i have had this problem before and was told by someone wanting to get more business that something was supposed to be there although i had never seen anything. so i just changed the shifter to b&m because i went through 4 factory cables thoughs pos plastic pieces just kept breaking with regular use?????????
58mark
Sep 21, 2015 07:21 PM
HikoriYami
Sep 21, 2015 07:11 PM
camaronils
Sep 20, 2015 02:57 PM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
