700R4 molex plug????
Old Aug 21, 2007 | 07:37 AM
pmkgraffix's Avatar
Car: 85 camaro Z28
Axle/Gears: Stock
Can anyone help me out. I have a 1985 camaro z28 we just removed all the tpI BS and am having the trans rebuilt. What is the molex plug going into the side of the trans for and will I need it anymore???
Thank you
Old Aug 21, 2007 | 11:13 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 700R4 molex plug????
It's a Weatherpak, not a Molex. It carries the wiring to lock up the TCC, which you'll need to deal with yourself after getting rid of the computer.
Old Aug 21, 2007 | 04:20 PM
pmkgraffix's Avatar
Car: 85 camaro Z28
Axle/Gears: Stock
Thanks for the info
Old Aug 21, 2007 | 08:05 PM
me2's Avatar
me2
Transmission: 700r
Axle/Gears: ford 3.55
Not to steal your thread but, can this case connector be removed without dropping the pan? How is it fastened to the case? Someone connected a wire to the case connecter without the pigtail, then filled the connector with silicone.
Old Aug 21, 2007 | 08:11 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You'll have to drop the pan. You might be able to get the connector out, but it'll still have wires connected inside the pan.
Old Aug 21, 2007 | 08:29 PM
me2's Avatar
me2
Transmission: 700r
Do you think it will come up far enough to remove the wires and replace the plug?
Old Aug 21, 2007 | 08:33 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I wouldn't think so. IIRC, the connector is installed from the bottom anyway, not the top.
Old Aug 21, 2007 | 08:42 PM
me2's Avatar
me2
Transmission: 700r
Thanks for the reply.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
TheTraut88
Sep 7, 2015 05:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
