Cleaning up after a T5 swap
Old Aug 24, 2007 | 09:47 PM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
hey all,
I finished my swap the auto is gone and the T5 is in. It works great and I can say it was worth every penny.
I have a couple of items to complete though
1) the reverse light switch, anyone know what color wires it is in the bundle that came off the auto shifter?
2) does the cruise control cancel go on the clutch or the brake (or should I rig up one for each?) ?
3) my trunk switch will only work if I plug in the automatic wiring harness to the black module that used to be attached to the auto shifter, any idea how to make this work properly? Using the auto module I think the car thinks it is in park
thx in advance for your help
Old Aug 24, 2007 | 10:25 PM
Synful's Avatar
Re: Cleaning up after a T5 swap
1. purple/yellow
2. typically goes on the brake but I can't remember for this car....i removed mine. i would say if you have the switch you can see which part of the pedal bracket it fits best on...brake or clutch
3. that's odd I didn't encounter this problem. make sure that you removed only wires and relays associated with the automatic transmission. there are several of those in the auto shifter area for the power windows and hatch release button.
Old Aug 25, 2007 | 06:32 PM
1. Reverse light wires are dark green and dark blue. Yellow & purple is the neutral safety switch.
2. There's a switch on both. The brake one is both vacuum and electric; the clutch one is vacuum only.
3. On a stick shift car, the trunk release is interlocked to the parking brake; if the engine is running, the parking brake must be on in order to release the hatch. Take a look at the connections available on the parking brake switch.
At least, that's how things were done on my 5-speed car with cruise, that I actually have, and have looked at.
Old Aug 25, 2007 | 07:59 PM
Synful's Avatar
odd.....my reverse light wires are purple/yellow
just went and looked at them today to make sure
Old Aug 25, 2007 | 08:06 PM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
I had to push in the clutch to pop the trunk when I swapped over. I never tried the e-brake.
ZZ3Astro
Aug 13, 2019 12:57 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Jerzyperson
Carburetors
Nov 13, 2015 01:07 AM
gta892000
Sep 16, 2015 12:37 AM
