Whats happening to my 700R4?
Car: Trans AM GTA 1989
Engine: 383 HSR AFR195 JRC Cam280/286
Transmission: T56 Conversion
Axle/Gears: 3.27 9bolt
Hi!
When my transmission is downshifting from 2nd-1st gear, there is a loud knocking, but only when the shifter is on D.
In O/D this knocking is almost not noticable.
This sound is just while downshifts and gear changes when the car stands still.
I replaced my tranny mounts ( now energy suspension , my previous mount was ripped in 2 pieces )
would be great if someone could help me with that problem...
what could it be? tcc? converter?
must be something that is differrent in D + O/D.....
today i tried to shift manually, the loudest shift noise is from 3rd to 2nd gear. in "D" it seems that the 3->2 downshift is way too late, ~ @10mph , after that, my tranny shifts immediately to first gear, i think....
greets from germany
alex
greets from germany
alex
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
Re: Whats happening to my 700R4?
mine does the same thing but mine has been built with every pressure mod there is and the tranny guy said when i have it in any other gear than o/d its got full line pressure. so 200psi when its downshifting is gonna make some noise... dont know if yours is stock or if its the same way on a stock tranny.
thanks for your reply,
i don't think that i have a built tranny...
in 2004, the pre-owner of my car replaced the tranny for about 3500$.
this should be a stock tranny, the parts in europe are much more expensive...
but i don't know if its really stock.....
maybe i'll find it out someday...
greetz
alex
greetz
alex
Engine: 383 LT1
you could always check the tv cable and make sure its not too tight... i know that would make clunking noises upshifting dont know if downshifting does it too though...
so i'll order new u-joints , perhaps it is really exactly the same thing....
next week it should be done... i hope so
