Drivetrain Vibration
Old Sep 4, 2007 | 09:54 PM
Frank Rizzo's Avatar
Please help! I have an issue where my car vibrates when I am in drive but stopped at a light/stop sign. If I shift the car into neutral the vibration stops. Any ideas on what the issue might be?
Old Sep 5, 2007 | 12:21 PM
Blue_Thunder's Avatar
Car: 1986 Chevy Iroc-Z28
Engine: 1989 TPI 350
Axle/Gears: stock 10 bolt with 2.73 gears
Re: Drivetrain Vibration
Can you tell where the vibration is comming from? Does it change with vehicle speed? It could be alot of things right now, the first thing I would look at is the tires. Make sure they have the same tread pattern or are very close. Second make sure they are balanced correctly. Is there any noise along with the vibration?. If there is a noise with the vibration then I would check the suspension and drivetrain. The driveshaft U-joints could be worn out or the driveshaft itself is not balanced. Those will give you a bad vibration. Check your ball joints and Tie rods to make sure they are not worn out.
Old Sep 6, 2007 | 09:26 PM
1QWIKZ's Avatar
Car: 88 Camaro
Engine: 355
Transmission: TH-350
possibly bad motor mounts...hmmm any other info like how is the motor running rough with some missing issues or nice and tight
Old Sep 7, 2007 | 08:52 PM
Thanks. I don't notice any issues when I am driving. It only occurs when I am stopped at a stop sign or red light and the trans is in drive. The dash has begun to rattle so to make it stop I shift the car into neutral until the light turns green again then I shift it back into drive. This is in no way a long term solution.
In order to change the mounts do I need to use a cherry picker to support the weight of the motor or is there some other method like jacking it from underneath to hold the weight?
Last edited by Frank Rizzo; Sep 7, 2007 at 08:54 PM. Reason: Automerged Doublepost
Old Sep 7, 2007 | 09:20 PM
1QWIKZ's Avatar
Car: 88 Camaro
Engine: 355
put a piece of wood between the jack and oil pan and not a piece of trim either lol...j/k
69GTOby
Apr 18, 2016 02:34 PM
sac92transam
Oct 7, 2015 02:31 PM
roysatikas
Sep 22, 2015 08:15 PM
BWilcox
Sep 20, 2015 12:19 PM
InfinityShade
Sep 18, 2015 08:32 PM
