700r4 Noises??? Easy Fix? Need help ASAP!
Old Aug 21, 2007 | 08:29 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
When I put it into drive and punch it at any speed, it makes a raspy Keeeesh sound. It only does it in drive. 1st and 2nd, no sounds. Is it an easy fix? It runs good, just full throttle it makes a funny sound.
Aaron
Old Aug 21, 2007 | 11:06 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: 700r4 Noises??? Easy Fix? Need help ASAP!
Any one? I don't want to mess it up to much more by driving it or anything., but I need to get to school, soccer, and work.
Old Aug 24, 2007 | 12:12 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Okay, I guess nobody knows.
Old Aug 24, 2007 | 01:40 AM
dekoy411's Avatar
Car: 1992 Camaro RS
Engine: 305 5.0L
Axle/Gears: Stock
Mines made that sound before too. It doesnt sound to good im expecting a rebuild soon sadly though i suppose it does have over 140k miles on my transmission. Im not sure what it is exactly though.
Old Aug 26, 2007 | 05:20 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Any other idea's? I really need to fix this. It is getting worse. Any help is really appreciated.
Old Aug 26, 2007 | 10:18 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Hmmm.
Old Aug 28, 2007 | 08:25 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
TTT.
Old Aug 29, 2007 | 12:27 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Only getting worse...
Old Aug 29, 2007 | 09:03 PM
dv013003's Avatar
Car: Firebird Formula 350
Engine: 5.7
I dont know what exactly the sound is which you are referring to, but mine has made a whining sound before at WOT. A mechanic I know said that whining at WOT could be from anything inside the tranny like bearings or the like. Because it is getting worse, it sounds like you need to ask a tranny shop.
Good Luck
Old Aug 29, 2007 | 09:22 PM
TransAM Joe's Avatar
as a long shot check your tranny mount and make sure it is not split in two allowing the tranny to jump around under high loads.
Old Sep 8, 2007 | 02:46 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
A bearing problem would suck. It only have 80,000 miles on it. Oh well. It sounds like the problem. And still, only getting worse.
Old Sep 8, 2007 | 04:38 PM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
check your mount as stated previously the torque arms break these easily.
also if thats good then it is an internal problem which needs to be fixed now.
mine made that type of sound and it was the drum that the 2/4 band applies to had been squeezed so hard that it fanned outward to the case almost cutting the case in half. (this was from blocking the 2 accumulators like the TCI super street kits)
theshackle
Sep 17, 2020 08:26 AM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Dkelz313
Apr 7, 2016 10:38 PM
hydrolic144
Sep 4, 2015 09:48 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
