Richmond Mini Spool?
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
I was kinda wondering how a mini spool would hold up in everyday driving on a stock 9 bolt.......its geared 3:73 but is open......would it work for a driver? or would it break my axles when i took a hard turn?
Car: 84 z28
Engine: 355
Transmission: TH350
Re: Richmond Mini Spool?
one more question........anybody know if a 700r4 drive shaft will work with a short tailed th350 in a 3rd gen?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Do they even make a mini spool for a 9 bolt? I was under the impression that there was a 26 spline mini spool for the 7.5" 10 bolt and maybe a 28 spline one but I've never seen one for a 9 bolt. Are you confusing it with a 9"?
A mini spool is designed for dirt track racing. It's hard on tires and axles on pavement and you shouldn't be driving on the street with locked axles anyway.
The 700R4 driveshaft works with a long tailshaft TH350. The short tailshaft TH350 needs the longer driveshaft from a 82-83 third gen that came with the metric 3 speed (TH200C).
Car: 84 z28
Engine: 355
Transmission: TH350
instead of hunting down one of those rare drive shafts like u were talkin about....would'nt it be easier just to change my tail shaft?
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
you would need to disassemble the trans to install a longer output shaft as well. just go to a junkyard and pull a th350 from a 73-87 longbed chevy pickup they all came with the 9" tail housing.
Car: 87 IROC L98
As mentioned above. The tailshaft goes from the inside out and it's at the back of the tranny. The entire tranny will need to be disassembled to simply "change the tailshaft". It will be easier to just find a long tailshaft TH350 or the longer driveshaft.
Just get a new driveshaft made to the proper length.
Car: 84 z28
Engine: 355
Transmission: TH350
got it all sorted out.......found a drive shaft out of a 82 camaro.....only thing i dont wanna do is get rid of my trans.....its built....kevlar clutches, shift kit....would kinda suck to go from that to a stock truck trans....
Car: 2000 BMW M5
Get a real posi. You are putting an unbelievable amount of stress on stock axles driving w/ a spool on the street. Plus it's downright dangerous, not having your rear tires differentiating. If you can't get a posi keep it open. But you can get an auburn used on ebay for $100 so there really is no excuse.
Car: 84 z28
Engine: 355
Transmission: TH350
tell me this then.....i counted the bolts around the rear end cover and mine has 9......would the stuff from a 10 bolt work in it, because in all the reading ive done they are both like 7.5
Car: 87 IROC L98
Then you have a Borg Warner 9 bolt. The only thing it has in common with the 10 bolt is external mounts. Wanting to use 10 bolt internal parts, you might as well try to install Ford 7.5" parts in it. You'll get the same results. They're 2 completely different diffs.
Parts for a 9 bolt are very hard to find if you can find anything. Your best source for 9 bolt parts is Australia. If you want to upgrade the diff, you're better off yanking out the 9 bolt and installing a 10 bolt. It's not much of an upgrade but there's a much better supply of parts.
There's always a complete diff swap to something aftermarket. A direct bolt in 12 bolt or Ford 9" is always a better option.
I also highly doubt your 9 bolt is 3.73 gear. Factory gear ratios were 2.77, 3.27, 3.45 and there was an over the counter ratio of 3.70 once.
Car: 87 IROC L98
www.spohn.net is one of the TGO sponsors and has good deals. Click on any of the banners you see on TGO for links to third gen parts.
There's a couple of manufactures who make a bolt in 9" for a third gen. The cheapest way is to buy the housing package. You get the housing and axles for about $1000. You then install your own brakes and center section.
A complete, ready to bolt in diff is around $2500.
Car: 84 z28
Engine: 355
Transmission: TH350
definatly dont wanna go that route.....thats more than i gave for the car...i found a 4th gen rear end on ebay......think it would fit?... i know they are like 3-4 inches wider than stock 3rd gens, but searching the forum and somebody
"thinks" it might work......dont wanna buy a part if i aint 100% sure she gonna work
Car: 87 IROC L98
4th gen diff is a direct bolt in but it isn't much of an upgrade. It's still the same tiny 7-5/8" ring gear but will have slightly larger 28 spline axles. The only problem using one is that it's about 2" wider on each side so proper backspaced rims are required to tuck the wheels back under the fenders. There will probably also be a problem with park brake cables.
darwinprice
17
Oct 11, 2015 11:51 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
