2004r into rs?
Car: '90 RS, '82 Z28, '86 Monte Carlo SS
Engine: 305, 350, 350
Transmission: none, 700r4, 2004r
Axle/Gears: 2.73, ?, 3.73
2004r into rs?
I have just acquired a '90 rs v-8 auto that is in great shape other that the tranny is shot. I have a couple 2004r's laying around and was wondering how hard is is to swap one into this car.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 2004r into rs?
It should be somewhat straightforward, as long as your 200-4R has the correct bolt pattern to fit a V8. The shift quadrants are the same, so your shifter will work.
The transmission mount location will be different and it won't have a torque arm mount, so you'll need to deal with that. The easiest way would probably be to use a torque arm and crossmember from Spohn or elsewhere that will bolt right in. You'll also need a different length driveshaft.
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Re: 2004r into rs?
Try to find the correct parts from a 89 TurboTA for the mounting and tailshaft. Good luck in that. But the Spohn parts are your best bet. And most 200R4s were a BOP pattern which is different than the SBC pattern.
Re: 2004r into rs?
The 2004r is in my monte right now behind a mild 350 so I know it bolts up. But I haven't worked on a third gen in a while so I forgot about the torque arm.
Engine: 383 Carb
Transmission: 4L60
Re: 2004r into rs?
TTA parts are uncommon enough that they're not worth trying to source. Most 200-4Rs were BOP but some were dual-pattern.
