wrong speedo gear or cluster?
Old Sep 14, 2007 | 08:21 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
Hi I just got an 87 ta 305tpi w/700r4. My speedo is 10mph slower than it should be. i thought it might be the gear but then i took apart the cluster(140 speedo) and noticed my cluster was missing ses and shift light bulbs so i moved brights and seatbelt bulbs. has an automatic ever come with a shift light or was this cluster taken from a 5speed for the 140 speedo. If it was how do i correct the gears for a 140mph if the original was 120 0r 85?thanks alot
Old Sep 14, 2007 | 08:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: wrong speedo gear or cluster?
Automatic clusters don't have shift light bulbs. If you put one in, it'll start turning on and off when your TCC locks and unlocks.
You don't do anything to the speedometer gears if you change speedometers. You only change speedometer gears if you change the diff ratio, or the tire height.
Old Sep 14, 2007 | 08:33 PM
The scale doesn't make any difference to what gears you need. On all the different speedos, the same # of degrees of pointer movement = the same # of mph; so the pointer always goes the same amount, say, 90° from 0 to 70 or whatever. Furthermore, the cable always spins the same; 1000 revs = 1 mile. Or, look at it a different way, 1000 RPM = 60 mph.
Sounds like you just need to get the right speedo gears.
AFAIK the clusters were the same between stick & auto; they just didn't put a bulb in the auto ones for the "shift now" light. In fact the same driver pin on the ECM is the shift light in auto cars and the TCC solenoid in auto cars; so if you have a auto ECM, it will light the "shift" light when the TCC is applied. Just leave that bulb out.
Your speedo is probably not "10 mph" off. That would mean it ALWAYS reads 10 mph different from the actual speed; sitting still, 60 mph, 150 mph, whatever. More likely it's a PROPORTION; like, it's 15% off, so it reads 1 mph off at 6 mph, 4.5 off at 30, ~10 off at 65, 15 off at 100, etc.
Speedos are SO SIMPLE. It's amusing how poorly they are understood by most people.
Old Sep 14, 2007 | 08:41 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
thanks for the info and it off 10mph at about 55mph im actually doin @ 65. thanks again
Old Sep 14, 2007 | 09:13 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Sure, but is it at 35 when you're doing 45?
Old Sep 15, 2007 | 07:35 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
no I was trying to say that I mistated the 10mph correction, its only at 55 that its off 10mph.
Jeremys87
Jul 14, 2022 09:08 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
355sbcTPI
Aug 19, 2015 04:38 PM
tnrednneck
Aug 13, 2015 08:57 AM
