ok, what did I just screw up??
Car: 89 Camaro, 00Xtreme s-10, 89 Buick "Party Ave"
Engine: 305tbi
Transmission: 700r
ok guys, heres what I did...I had swapped a 700r tranny into a carbed car here awhile back.... I used a toggle switch to manually lock my torq converter when on the highway....all was fine till lastnight...that was untill I forgot to flip the switch OFF when I got home and parked the car...it sat overnight with the switch to the torq converter ON....this morning I noticed it...and turned it off...then later I started the car...it cranked slow...and stunbled while it was running9like the cnverter is still locked)....I fliped the switch back-n-fourth...but it still ran like ****...I backed it out of the garage...and back in cause it was stumbling and jerking....so, what did I screw up by leaving the switch ON...and how can I fix it
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: ok, what did I just screw up??
Depending on how you wired your switch, the worst you could have done is drain the battery.
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
if the converter were truly locked still then it would have the effect of letting the clutch out too fast when put in gear.(I.E. it would stall) your stumbling problem could just be low voltage. get a good charge on your battery before you try to diagnose.(use 110 volt battery charger)
Engine: 383 Carb
Transmission: 4L60
The TCC can only be locked when the transmission is in second gear or above, regardless of whether the solenoid is powered or not.
Engine: 305tbi
Transmission: 700r
update, ok I had disconnected the battery and let it sit a day...then went back to it and reconnected the battery...and started it up...it fired right up and now acts fine...you were probably right the battery probably got low...i have the toggle switch wired thru tha adl termanal like is described in the tech artlcles...thanx
RedLeader289
May 28, 2019 01:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
