Differrent versions of 700R4's?
Old Sep 17, 2007 | 11:03 AM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Axle/Gears: Borg Warner 9 bolt w/3.27 lim. slip
I'm running the 700R4 from my '84 5.0 Z/28 in my '54 Chevy pick up. I was told it's not as good as the one I have in my '88 IROC with the 5.7 motor. What year did they change and what differences are there? Thanks Daniel U
Old Sep 17, 2007 | 11:41 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Differrent versions of 700R4's?
There were incremental improvements in pretty much every year. Probably most significant was the addition of the auxiliary valvebody in 1987. Most other changes can be retrofitted during a rebuild.
Old Sep 17, 2007 | 11:42 AM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
How did this make them better/stronger?
Old Sep 17, 2007 | 12:16 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
How did which, the auxiliary valvebody? It has forward and reverse accumulators to soften the initial shift into gear.
Old Sep 17, 2007 | 05:10 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Thanks for the info. I like to learn as much as I can.
Old Sep 17, 2007 | 05:36 PM
Burntz's Avatar
Car: 1986 Trans Am
Engine: Mild 10:1 355.
Axle/Gears: 9 bolt
also, in 87, correct me if i'm wrong, but i thought they changed the spline count from 27 to 31, and made the input or output shaft stronger?
Old Sep 17, 2007 | 05:44 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The input shaft spline count was changed between 83 and 84 in V8 transmissions, V6s still used the smaller shaft. The larger input shaft could still be put in an older case.
Old Sep 17, 2007 | 06:12 PM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Like already mentioned the 87-up had the softer engagement via the Aux VB. But more inprovements were made in the internals like the 3-4 clutchpack which was a problem area in 89-up. IMO get the latest version. 1993 was the last year for the 4L60/700R4 B4 it became a computer controled tranny. Hence the E at the end of the 4L60E. Most 89- up are now referred to as the 4L60 trans. GM just changed and unified their ID system on the trannys. Dropping the old TH (TurboHydramatic) moniker. Hope this helps.
3rdgenparts
May 21, 2016 11:50 PM
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
