4.10 vs 3.73
Old Sep 18, 2007 | 09:09 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
4.10 vs 3.73
Looking for a new rear end and was wondering if i should go with the 4.10 gears or the 3.73. i will be dragging and driving on the street. I want good track times but yet good street mileage. What are the advantages of both and what rpms would you be running at 60 mph with the 4.10
Old Sep 18, 2007 | 10:35 PM
sschevy01ss's Avatar
Re: 4.10 vs 3.73
I would prefer 3.73 man.. you dont tach out as high and you have more chances to chew up your engine with 4.10.. 3.73 is like dead center.. has the power to take off quicker and you have the speed to go along with it. remember.. more RPMs you have to run at certain speed.. the more chances to hit your redline and chew things up in a nasty way and costs more money.
Old Sep 19, 2007 | 03:53 PM
1BadaGTA's Avatar
Car: 1991 Gta trans am
Engine: 383ci,trickflow alum. heads, hsr
Transmission: T-56, alumin. driveshaft
Axle/Gears: stock 7.5"/3.42
Re: 4.10 vs 3.73
Go for the 3.73's I put them in mine because I was thinking the same thing as you. I didn't want to lose top end though....so the 3.73's were/are the better choice if you ask me.
Old Sep 20, 2007 | 09:05 AM
a/fool's Avatar
Car: 78 Z28
Transmission: 3500/th350
Axle/Gears: 5.13
Re: 4.10 vs 3.73
the simplified formula: rpm = (mph x final gear ratio x 336*) / tire diameter
if you have overdrive multiply that by the final drive ratio.
for the best E.T.'s you would like to cross the finish line about 200 rpm over redline.
figure out how much your car weighs, and how much power you are making. then use this simple chart, and gear accordingly.
http://www.freewebs.com/soslo/formulas.htm#hp_et_chart
or try this one for a street car http://www.4lo.com/calc/geartable.htm
Last edited by a/fool; Sep 20, 2007 at 11:40 AM. Reason: chart didn't come out right
Old Sep 21, 2007 | 09:40 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Re: 4.10 vs 3.73
3.73 for an auto.....4.10 for a manual
I went with 3.73 that way im at the end of 3rd gear be the time I reach the 1/4 mile.
6speedIROC
16
Mar 15, 2023 08:33 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
S10K20
Oct 7, 2015 06:45 PM
JSDaddy189
Sep 26, 2015 03:50 PM
whyt86roc
Sep 10, 2015 10:03 PM
