B&M shifter problem
B&M shifter problem
We installed a B&M shifter in my friend's Iroc with 700R4.
All is well except when we try to shift 2-3 at WOT there is a delay after we shift it. We know the lever underneath is shifting but the gear won't change until we lay back on the pedal. Any thoughts? Perhaps more fine tuning/adjustments of the swivel on the shifter cable that attaches to the transmission lever?
Axle/Gears: '01 3.42 10 bolt
Re: B&M shifter problem
if the shifter is moving the lever on the transmission properly, then the delay is in the transmission itself. the shifter doesn't determine shiftpoints.
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
X3 also did you install a shiftkit on the valvebody to give you manual controll? if not you need to. dammage results in the earlier 700's from manually shifting in stock form.
