how much heavier is the th400 than the 350?
Old Sep 26, 2007 | 02:11 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
concerning my bbc swap i was wondering really how much heavier is the 400 versus the 350? everyone is suggesting that i use the stronger 400 than the 350 so i was wondering what the weight diff. is thanxs
Old Sep 26, 2007 | 04:20 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Re: how much heavier is the th400 than the 350?
I believe the rotating assembly is 10# heavier.....35 #`s for the TH350. It depends on how much power you are after but I was skeptical too when I put the 350 in, with the proper set up and parts mine has been good aside from a case failure early this year.
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
john204481
Sep 7, 2015 03:22 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
