700r4 overdrive blowing guages fuse?
Old Sep 27, 2007 | 07:45 PM
IROC_5796's Avatar
Car: '91 vert RS, '82 Z28
Engine: TBI 305, TPI 350
Transmission: Auto, 5 speed
can some one help me, i just bought a new rebuilt trans had it installed at a shop and now the guages fuse blows when the car shifts into overdrive. im thinking somthing is wrong with the stall but i really have no idea. not sure whats going on anyone have any ideas, i need to get this fixed fast.
Old Sep 27, 2007 | 07:51 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 700r4 overdrive blowing guages fuse?
You have a short in the torque converter clutch circuit.
Old Sep 27, 2007 | 08:51 PM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
The gagues fuse supplies 12Volts to both the Gagues and the TCC 4th Lockup circuit. A Pink-Black wire leaves that fuse and goes to one of the Brake Switches at the brake pedal. The one you want has a Pink-Black in and a Purple out. From there the purple goes down to the plug on the transmission. Drivers side, halfway back and up pointing downward..its a 4-pin with 3 wires. Inside it goes to the TCC Solenoid. 1st step I would do is Unplug the 4-pin plug at the tranny. Install a new fuse, start up the car and hit the brake a few times. If the fuse blows, the BrakeSwitch is the sulprit. But most likely its not. Otherwise, they wired the TCC circuit incorectly and that is connected to a grounding pressure switch, which its not suposed to be. Or your TCC solenoind is bad and causing a dead short. Hope this helps.
thunder57
Nov 7, 2015 02:28 PM
tmellott89
Oct 14, 2015 02:06 PM
92projectcamaro
Sep 29, 2015 07:07 PM
6998poncho
Sep 25, 2015 02:56 PM
lanceflame44
Sep 25, 2015 12:28 PM
